12-06-2018, 12:05 AM | #26 |
Re: FiTech checklist
Im happy with the setup and don't mind the frame mount pump, works fine. I did encounter an issue with the fuel pump leaking upon initial startup but found the culprit to be a gently shaved thread on the fitting going into the pump itself. Take your time when installing the fittings the smallest issue can cause a leak. Also the knife switch needs to be added to the negative terminal when installing to act like a kill switch, simple yet I looked over it during the setup .
