Old 08-23-2018, 10:29 PM   #26
saxart
saxart's Avatar
Re: Who has a kill switch in their truck?
Originally Posted by dmjlambert View Post
The best kill switch would be one that if not switched on it would still allow the truck to be started, but then would sputter and die after 5 to 10 seconds, try again same thing happens, and then would not start at all the 3rd and subsequent attempts.
I've thought about putting a 1/4 turn ball valve on the short rubber fuel line that resides under the cab. Shut the valve off when you leave the truck, it will only get said thief about a half mile down the road. Downside is you'd have to crawl under the truck to make it work, but I'm guessing it would be pretty fool-proof.
Meet "Old Roy": http://67-72chevytrucks.com/vboard/s...d.php?t=707801
saxart is offline   Reply With Quote
Old 08-24-2018, 09:24 AM   #27
rpmerf
rpmerf's Avatar
When I got my truck, the Neutral Safety Switch was misaligned. You needed to move the shifter past park to get the starter to turn. Unfortunately, that means that it does not work in neutral anymore.
With a cold engine, most people wouldn't know they need to set the choke, much less to crank it for 10 seconds to fill the bowl and pump the gas a couple times.
Of course with no hood lock, steering lock, shifter lock, the biggest thing keeping people from stealing the truck is keeping the doors locked.
1970 C20 Custom Camper - 350, TH350
1997 GMC Suburban
1994 Acura Integra GSR
1987 Dodge Daytona Shelby Z
rpmerf is offline   Reply With Quote
