#1 | |
![]() Join Date: Mar 2012
Re: DIY Exhaust - Cutting Tubing
It's rare to hear someone say they have to remove an exhaust shield because parts are not heating up enough. Also, to the OP, I was taught to cut pipe with a hack saw by a pipefitter from a paper mill. Paper slurry will build up and plug a pipe in a hurry if the joints aren't perfect. The trick to good cuts and joints that fil together well is to use a good pattern and to cut small sections at a time with the saw. A band of paper taped to the pipe, wrapped around, and taped back to itself serves as a guide. Cut a little, turn the pipe, cut again. Works well. Last edited by 1project2many; 07-16-2018 at 10:22 PM. |
Thanks for all the info guys. And a tool I've never seen before.
I'm definitely going to try it. |
Ok, one more question.
S10 swap build. I kept the stock transmission cross member (narrowed). But then decided on a 4link, and moved the tank to the rear. For simplicity sake, do I build a new cross member to run straight duals, or snake around to the passengers side, then back across for split exhaust? |
#4 | |
cool, an ogre smiley Ogre's 58 Truk buildhow to put your truck year and build thread into your signature shop air compressor timer |
My idea of shortening the donors exhaust didn't really work. It hangs below the frame a little. So I'll be watching what b-mac does.
Check out what I noticed. Not sure how I missed it but when the shop put in my motor I'm guessing exhaust manifold was already messed up orbthey messed it up.
1950 Build |
#6 | |
Not sure what engine you're running but maybe different manifolds or headers could get you closer to the block. |
most of truk exhaust hangs under the frame above the scrub line
I have $677 in materials for my stainless 2.5" mandrel bent dual exhaust. With Magnaflow mufflers and dual catalytic converters. I'm pretty sure if I dropped it off at a shop, the bill would be double that.
$4oo.
| Bookmarks |
