Old 07-20-2018, 12:48 PM   #26
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
Re: LED Headlight Conversion
How about just putting relays and pull the power off the battery and not through the switch?
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 07-20-2018, 04:33 PM   #27
Robert Haas
Originally Posted by aerochris View Post
Thanks everyone for the info. I am happy enough with the light output of the factory lights. The problem is when the lights are on, the cooling fan is on, and the A/C is on, there is a big drain on the system. The lights seemed like the easiest thing to modify to ease the load. I'm hoping to find some LED's that won't break the bank.
If that is the only reason you are updating, honestly if you were to just swap out your alternator to a 100 amp unit and run a serious battery you should never have a problem again.
Robert Haas is offline   Reply With Quote
Old 07-20-2018, 05:11 PM   #28
Bernie M
I sure wish they would outlaw Led lights , I know they the new thing but man when you are driving the other way they hurt... If your are in your work car at 4:00 am in the rain. The new Ford trucks are BAD Wow!
Maybe I am old?
Bernie M is offline   Reply With Quote
Old 07-20-2018, 06:49 PM   #29
Cooper197
Cooper197's Avatar
https://www.theretrofitsource.com/mo...dlights-7.html
Check these out for a budget friendly LED swap. They are what I run and they easily keep up with the $600 sets for $150. Highly discounted due to being an old generation of them.
Cooper197 is offline   Reply With Quote
Old 07-20-2018, 08:05 PM   #30
aerochris
aerochris's Avatar
Those look good. Not sure how the black will look next to the chrome. Do you think the anti flicker harness is needed?
aerochris is offline   Reply With Quote
Old 07-20-2018, 08:12 PM   #31
Cooper197
Cooper197's Avatar
I didn’t check to see if there were chrome left, not sure how the black would look.
I have them on mine with no anti flicker and they’re just fine. I don’t see a need for the anti flicker harness.
Old 07-21-2018, 12:16 AM   #32
Captainfab
60-66 Nut
It sounds to me like what you really need is an alternator upgrade and a relay setup for your headlights.
Old 07-21-2018, 10:58 AM   #33
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Not sure if it matters to most, but the Morimotos' aren't DOT.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 07-21-2018, 12:47 PM   #34
Cooper197
Cooper197's Avatar
The Morimoto's are stamped DOT SAE, so I believe they are DOT legal.
Old 07-21-2018, 06:07 PM   #35
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
I only mentioned it because I didn't see anything about DOT on the spec page, nor could I see it on the lenses in the picture. If yours actually have that stamped, then they probably are.
Old 07-21-2018, 06:22 PM   #36
Cooper197
Cooper197's Avatar
I know it does not say it on their page, which is strange. However mine are stamped.
Old 07-23-2018, 11:03 AM   #37
chevy_mike
Never Ending Projects
chevy_mike's Avatar
Just because the item has the DOT stamp, doesn't mean it really is. If the company cannot prove (and normally they are proud that they are and will post it on their site) DOT testing, these could be a fake DOT stamp. This is VERY common with Chinese lighting.
Look at J.W. Speaker's site, DOT info is all over it, http://www.jwspeaker.com/products/le...8700-evo-2-db/
1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD
1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD
1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD
We were given two ears and one mouth for a reason... listen twice as much and speak half as often...
chevy_mike is offline   Reply With Quote
Old 07-23-2018, 11:14 AM   #38
Cooper197
Cooper197's Avatar
Looking again, it does have the info on their website, just not the distributor page I ordered from. They aren’t cheap Chinese crap headlights, they give the JW’s a run for their money.
Old 07-23-2018, 12:59 PM   #39
aerochris
aerochris's Avatar
Well I went with the MORIMOTO's. I'm not sure when they will get here but looking forward to trying them out. Do you guys use the DRL feature or just leave it unhooked?
Old 07-25-2018, 02:08 AM   #40
63burban
Chevy addict
Good battery, 105 amp alternator and a United Pacific relay set up with halogen headlights work great and brite
63burban is offline   Reply With Quote
Old 09-11-2019, 11:13 PM   #41
BigTopGT
Bringing this one up from the grave: What harness do you use to hook everything up? (‘are they plug and play, at all?)
I’m going to order these tomorrow once I know how to install them.
BigTopGT is offline   Reply With Quote
Old 09-12-2019, 12:13 AM   #42
Cooper197
Cooper197's Avatar
I believe they are standard H4 plugs, so it was all plug and play.
Old 09-12-2019, 08:12 AM   #43
kens65fb
What type of lights are these
kens65fb is offline   Reply With Quote
Old 09-13-2019, 06:12 PM   #44
oldtrux
oldtrux's Avatar
Anyone know if the cibie h4’s fit in buckets without modifications?
Thx
oldtrux is offline   Reply With Quote
Old 09-14-2019, 09:18 PM   #45
BigTopGT
Thanks man!
I’ll order the lights and harnesses tomorrow.
Old 09-14-2019, 09:32 PM   #46
norcalcap
Thx
They do. Purchased Cibie H4's for my 65. Fit perfect. No mods.
norcalcap is offline   Reply With Quote
Old 09-28-2019, 05:43 PM   #47
BigTopGT
I picked up the Morimotos, too, but I'm having a little fitment issue.
Are you guys simply trimming the bucket for fitment?
Also, anyone have a recommendation for the hookup point for the tan wire, which I assume is either a DRL or turn signal feature?
Old 09-29-2019, 11:01 PM   #48
BigTopGT
UPDATE:
I cut the factory buckets to let the Morimotos sit down far enough to screw down the retaining ring.
Glad I have spares.
