03-18-2020, 04:43 PM | #26 |
Re: D99 paint divider trim
where are the Pop Rivet studs available?
1968 C20 Fleetside 396 4sp PS PB AC CST . https://www.youtube.com/watch?v=RWK8GgWD4uA |
03-18-2020, 04:45 PM | #27 |
That makes more sense. That way the ends of the trim would be hidden. I’m still banging out dents and fixing rust. Maybe I’ll get to paint it this summer.
03-18-2020, 07:24 PM | #28 |
1967 Factory short bed - Old school '71 - 350 / 4bolt / 487 heads / Edelbrock C3BX Muncie M-22 4 speed / Hurst Comp plus Factory 12 bolt posi 3.73 / 255-70-15 Smoothed firewall / Factory cowl induction Power disc brakes / power steering / 3.5-5" drop |
03-18-2020, 07:44 PM | #29 |
1967 Factory short bed - Old school '71 - 350 / 4bolt / 487 heads / Edelbrock C3BX Muncie M-22 4 speed / Hurst Comp plus Factory 12 bolt posi 3.73 / 255-70-15 Smoothed firewall / Factory cowl induction Power disc brakes / power steering / 3.5-5" drop Last edited by Grumpy old man; 12-06-2020 at 10:33 AM. |
12-06-2020, 10:33 AM | #30 |
back to the top for some good info
and they lowered the price ,
1967 Factory short bed - Old school '71 - 350 / 4bolt / 487 heads / Edelbrock C3BX Muncie M-22 4 speed / Hurst Comp plus Factory 12 bolt posi 3.73 / 255-70-15 Smoothed firewall / Factory cowl induction Power disc brakes / power steering / 3.5-5" drop Last edited by Grumpy old man; 12-06-2020 at 11:25 AM. |
12-06-2020, 11:14 AM | #31 |
Thank You Grumpy !
About to install my trim on my 72 stepside...These look like a better idea than using the small screws. |
12-09-2020, 01:05 AM | #32 |
Perfect, just what I need. thanks for the links!
12-14-2020, 05:00 PM | #33 |
OK...I got the rivets & installed them today. Very satisfied with the results.
Just some additional info.....The rivets need to have a #39 (.099) hole drilled in the cab to get a tight fit. Also the pull pins on these rivets are .055 diameter. My rivet gun would not work, but I borrowed one from a friend that had the correct size to fit the pull pins. I put a dab of seam sealer on each before setting the rivets to assure a watertight seal. |
12-14-2020, 08:42 PM | #34 |
Which rivets did you buy? I need to place an order for some also
Terry 1970 Custom Camper/C20 , GM Crate 350/7004R, Dana 60, factory AC |
12-15-2020, 09:39 AM | #35 |
12-15-2020, 01:37 PM | #36 |
I've used small flathead screws to attach the plastic clips. worked great Pick them up at any hardware store.
05-23-2021, 10:07 AM | #37 |
Has anyone used the rivets after paint?
1967 C10 SWB Owner - Rustbelt Restorations |
05-23-2021, 09:42 PM | #38 |
I don’t see why you couldn’t.
1956 Chevy Bel Air 2 door 1956 Chevy 210 4 Door 1970 K20 LWB project the Hulk build w/Supercharged 4.8L-ly2/4L60E HULK BUILD 1970 C10 Yellow/White Deluxe LWB w/ 5.3L-LC9/6L80E 1968 K10 LWB Dark green my son calls it "THE HULK Jr"HULK JR *SOLD* GO GO!!! |
05-31-2021, 10:43 AM | #39 |
Do you have any measurements for the placement of these studs? Mine doesn't have the divider trim, but I am going two tone so I want to put the trim on.
05-31-2021, 11:01 AM | #40 |
