#26 |
![]() Join Date: Dec 1999
Re: 3 on the tree trouble shifting
The 3OTT linkage really is not that complicated. There is no magic. It appears you have messed with it enough now to figure that out.
With all the talk of not being able to get it into gears I keep wondering if you have checked the fluid level in the transmission? In the last picture you posted did you ever get those adjusted to be closer together? |
#27 |
![]() Join Date: Jul 2018
I did finally get it closer. I did attempt to check but without getting it on a lift or atleast higher than I can get it at home I cant be certain. When summit gets me the parts Im going to have my mechanic install the new carb/manifold and once it all over. If it xost me $500, thats better than the hours Ive spent tinkering and breaking down on the side of the road. Luckily ive got a dual axle trailer for my tractor I was able to tow it home the one time, that would have been an easy 150+ right there. The one thing I did notice last night when it cut off was gas dripping off the passenger side of where the carb meets the spacer the previous owner put on.
Posted via Mobile Device |
#28 |
Shifting 3 on the colum takes a little finesse. Don,t force shift or power shift.
And downshift into first gear only after you have stopped. |
#29 |
You can still downshift to first but you need to rev-match to make it smooth. I do it all the time. About 90% of the time I'm driving my truck it's in stop and go traffic. Lots of shifting.
#30 |
#31 |
Good to know on shifting. I drove a 4 speed m-22 years ago in a nova. My neighbor has a chevelle and suggested powershifting. Im glad to hear to just clutch it in and stop then first gear.
Jason, super clean engine bay, and thanks for the words. Posted via Mobile Device |
#32 |
Well messed with the alignment again and it just wont shift 2nd and 3rd now. Did it last night, and again when I got home. I just cant win here. It went 1, 2, 3 smootgly one time. Then got hung up, several times it just went up and dien between arms and never grabbed anything. Seriously thinking of finding a used floor 3 speed.
#33 |
Who's got steelies?
![]() Join Date: Feb 2006
Are all the bushings tight? If there is any lost motion, it will not shift right. When you move the levers on the column, the levers on the transmission should move, with no slack in the linkage.
![]() ![]() ![]() ![]() ![]() ![]() How to add a trip odometer to your 67-72 stock speedometer How to rebuild your Q-Jet My Truck Page My Youtube Channel |
#34 |
They still wiggle, Ive got the nuts tightened as much as I can without feeling like Im over doing it. The thing that gets me the most is the actual shift lever on the column is flimsy as all get out. What I dont get is how I just did this last week, rode fine for 5 minutes, then now Im back at square one. I also dont have it greased up like a fast food burger as I was waiting till I knew it was good to go or else Id have my hands back in globs of grease.
Posted via Mobile Device Last edited by SC1969c10; 08-13-2018 at 10:09 PM. |
#35 |
![]() Join Date: Dec 2013
I've got a few of them in the garage ,I'll take some pictures tonight . It's a standard H pattern shifter , Once adjusted with the Trans levers in Neutral you have to pull back to shift into Reverse or first then push forward when shifting up to second and down to third .
#36 |
Take the pin out that holds the shift lever in...pull out the shift lever and spray a ton of WD40 in the hole. Put the lever back on and run the shifter through the gears as best you can. I would follow this up at another time with some 'light oil' of some type that will stick around better than the WD40.
I also still wonder about the fluid level in the trans, since having low fluid can make it difficult to get into gear sometimes. |
#37 |
Thats the only thing left that I havent done, check that actual fluid level in the tranny. Sprayed the shift lever real good last week when I took the column apart. Watched a handful of youtube videos on these things for both repairing and driving to see if Im missing something
Adjusting/aligning https://m.youtube.com/watch?v=2TCHzIvAvRQ Lubing shifter in cab https://m.youtube.com/watch?v=M2QzaV2S0Gg Both pretty helpful videos Tried the aligning 4 times tonight with no success. Last edited by SC1969c10; 08-13-2018 at 09:27 PM. |
#38 |
Is it possible to convert to a floor shifter without swamping the entire transmission out?
#39 | |
https://www.summitracing.com/parts/huu-3670006?seid=srese1&cm_mmc=pla-google-_-shopping-_-srese1-_-hurst-shifters&gclid=EAIaIQobChMIr6ipzMPr3AIVCLnACh15nAe0EAQYAiABEgJy2_D_BwE Posted via Mobile Device |
#40 |
That's just the install kit ,You need to add another $225.00 for the shifter so about $400.00 to convert to floor shift .
#41 | |
#42 |
And another $35.86 + shipping for the back up lights switch .
![]() ![]() https://www.summitracing.com/parts/h...SABEgJqJvD_BwE |
#43 | |
Who's got steelies?
What would probably give you the most bang and allow you to keep the three-on-the-tree would be this link rod that Lokar sells. I used one in my burb to connect a factory column to the transmission. The auto transmission linkage between the column and transmission is the same as it is on the 3 speed, and is the weakest link in both. If you disconnect the linkage from the transmission and shift the two levers at the tans bv hand, you will feel the detent inside the trans. Can you feel the detents when shifting inside the cab?
#44 | |
![]() With the wisdom and advice available here, I know you'll get there... and you'll be proud to have done it and to understand this "contraption" a thousand times better. ![]() |
#45 |
Good info in this thread. While mine's not this bad 1-2 shift can be a bit difficult and on a couple of occasions I've had to pop the hood and re-align the levers. Looks like I need to order some new bushings!
Ryan 1967 Red Stepside..."Laymond" http://67-72chevytrucks.com/vboard/s...40#post6441840 1972 Medium Olive SWB-Chester http://67-72chevytrucks.com/vboard/s...d.php?t=759628 1967/71 Blue SWB C10..SOLD 1977 SWB K10..my grandpa's.....never should have sold |
#46 | |
https://www.jegs.com/p/Lokar/Lokar-Column-Shift-Billet-Linkage-Kit/749836/10002/-1 I have to be brutally honest, without being more experienced with transmissions, I wouldnt know if I was feeling it or not. Metal sleeves are in bushings, didnt seem worn or in any way damaged Is it possible to have over tightened the cam? Started to tinker today only to have same results so I just walked away. Posted via Mobile Device |
#47 |
![]() Join Date: Nov 2006
Yep the top and bottom bushings are bad. Common........ You can change em out in 10 minutes
I BELIEVE IN JOHN 3:16 |
#48 |
Can someone snap a picture of theirs? I just noticed while re-watching this youtube video
https://m.youtube.com/watch?v=2TCHzIvAvRQ The nut holding his 2nd/3rd gear arm is on the inside of the lever, where mine is outside. Posted via Mobile Device |
#49 |
My rods are on like you have pictured in this post:
http://67-72chevytrucks.com/vboard/s...2&postcount=32 The rods are toward the front of truck on the arms and the nuts are towards the firewall. This picture is before my underhood cleanup: ![]() |
#50 | |
Who's got steelies?
Yes, it is possible to over tighten the cam. You want to adjust it so that the part in between the two levers can engage only one lever, and then when you pull the shift handle towards you it will engage the other lever. Also make sure that when one lever is engaged and moved from the neutral point, that the middle part is blocked from disengaging the lever it is engaged with. It might be that when you have this all adjusted, you can hold the lever halfway while everything is in neutral and the middle part will engage on both levers, but as long as it cannot disengage one lever until both levers are in neutral position, this is OK. At this point you should take the rods off the the transmission and operate the two levers by hand to make sure they work correctly and that the problem isn't actually at the transmission. One lever is the 1st/reverse, the other is the 2nd/3rd. Move one lever from neutral to a gear, you should feel the detent inside the transmission cause the lever to snap into position. The other lever still in neutral should be locked into the neutral position now, an interlock mechanism inside the transmission prevents being in 2 gears at once. Check both levers this way in all combinations. Once you have that, adjust the neutral point, using the 3/16" drill bit as others have mentioned. This is the tricky part, and is where the bushings need to be tight, no slop, because the column and transmission work together to perform the shifting action. Every time you operate the shifter, when you return the transmission to neutral, the levers on the column should always return to where you adjusted them, and not be off, if they are off, it means the bushings are worn or the pinch bolts are not holding.
![]() ![]() ![]() ![]() ![]() ![]() How to add a trip odometer to your 67-72 stock speedometer How to rebuild your Q-Jet My Truck Page My Youtube Channel Last edited by oldgold70c10; 08-15-2018 at 08:31 AM. |
