08-12-2018, 10:36 PM | #26 |
Who Changed This?
Re: Harmonic b
Yup, that's the sound I was talking about. Right on!
08-13-2018, 01:20 AM | #27 |
Re: Harmonic b
I'm installing one myself soon. Here's an excellent video, this guy is real good, though he seems to have more faith in experience than torque wrenches https://www.youtube.com/watch?v=R7BuijqjcUk
Not saying you didn't, but the bolt inserted into the crank has to bottom out. Otherwise you're tearing up threads as you tighten the balancer.
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
08-13-2018, 07:50 AM | #28 |
Re: Harmonic b
Here is an explanation of why you apply grease to the back of the crank seal , It's just a safety measure but if the spring does come off when your replacing the seal with the timing cover on the engine it eventually will end up in your oil pan and nobody wants pieces of spring steel getting sucked up into your oil pump . I've seen it happen . This is why I pull timing covers to replace crank seals .
https://www.youtube.com/watch?v=WOfOHMI6Wnc https://www.youtube.com/watch?v=1MzHlqQFHcs Last edited by Grumpy old man; 08-13-2018 at 08:04 AM. |
08-13-2018, 09:44 AM | #29 | |
Posted via Mobile Device |
08-13-2018, 09:45 AM | #30 | |
08-13-2018, 09:48 AM | #31 |
08-24-2018, 03:47 PM | #32 |
Re: Harmonic b
Well folks got the truck started sounded good but now we have hemorrhage from the bottom of timing cover /oil pan meet ,would it be safe to say its the oil pan gasket ,i did replace the half moon one but i guess it did not seat correctly ,thanks again
08-24-2018, 04:30 PM | #33 |
Re: Harmonic b
Did you use the right one?
There are two. Different thicknesses. |
08-24-2018, 05:04 PM | #34 |
Re: Harmonic b
Back to your messed up threads in the snout of the crank.
Google "Bottoming Tap". You can usually cut a few more threads in there with one.
'70 cab, '71 chassis, 383, TH350, NP205. '71 Malibu convertible '72 Malibu hard top Center City, MN |
08-24-2018, 09:56 PM | #35 |
Re: Harmonic b
I've seen people drill out a crank with stripped threads and rethread it for a larger bolt, I believe it was a 3/4 bolt.
08-24-2018, 10:00 PM | #36 |
08-24-2018, 10:02 PM | #37 |
Re: Harmonic b
Did you lower the pan when you put the timing cover back on?
08-24-2018, 10:03 PM | #38 | |
08-24-2018, 10:05 PM | #39 |
08-25-2018, 08:35 AM | #40 |
08-25-2018, 08:44 AM | #41 |
Re: Harmonic b
Oh, oh is right.
Likely knocked the gasket outta place. There’s two ways to fix it. One is drop the front of the pan about 1/2 inch so the timing cover gasket stays in place. Two is leave the pan alone and modify the cover bottom channel. Like this. Pic-in here and explanation. https://forums.iboats.com/forum/engi...ng-the-oil-pan |
08-25-2018, 08:54 AM | #42 | |
08-25-2018, 09:03 AM | #43 | |
Thanks for the info and help.. Posted via Mobile Device |
