#26 |
Re: Torsion box cut out?
Does anyone have any advice on removing my old one w/o damaging the frame? Or are there threads (that I haven't found) showing that?
My left one was removed by the PO to install a poor fuel tank install and the right one is rusted through.
72 Blazer, 70 El Camino SS, Anniversary HD FatBoy, 2020 Ram 2500, 80 Vette, 65 Chevy 3/4 Ton 4 W/D Pickup and some more. Wife: 06 GMC Duramax 3500 4WD Single Wheel Next: Rust removal on my Blazer. Thinking of putting a 50 Chevy cab on a 76 Chev 4 WD pickup. ![]() Members Met: Aldtime, DeadheadNM |
#27 |
It doesnt attach to the frame at all. It's only a body/tub brace.
#28 |
![]() Join Date: Jan 2007
- if all the body is still lined up - they are easy to install with a bit of welding along the bottom of the tub - they are bolted to the tub at the B-pillar.
#29 |
Got ya. I was just concerned about cutting those welds in the oval holes without damaging the tub/brace.
#30 |
Sure, i get it you dont want to muck up the floor/other panels it's welded to - well just like cutting/grinding into any weld to separate two panels do your best not to get into the panel you DONT want to cut/remove.
Patience is your friend. Grind some, check the progress. repeat. Also having some sharp chisels or other tools to help pry on the torsion box/show you where the weld is still hanging on is helpful. |
#31 |
![]() Join Date: Jun 2002
Removing mine was a combination of 4" grinder with cutoff wheels, sawzall, hammer and chisel, bloody knuckles, and much cussing.
Have fun! Rg
Roger '68 Short step - https://67-72chevytrucks.com/vboard/...d.php?t=849675 '69 ('70?) 2wd Blazer - https://67-72chevytrucks.com/vboard/...d.php?t=856475 '70 GMC Jimmy 2wd '73 Firebird - https://67-72chevytrucks.com/vboard/...d.php?t=853203 Ideas - https://67-72chevytrucks.com/vboard/...d.php?t=851743 |
#32 |
I took this pic soon after I pulled the tank the PO put in. It hung down 3+ inches from the bottom of the truck.
Soon, I get to remove the flimsy fuel door. Anyone interested in an aux fuel tank setup?
#33 |
Someone was looking for a fuel door over on the truck forum a week or two ago.
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson 1972 K/5 Blazer CST 4WD 1963 Corvair Monza Spyder Turbo convertible 1995 Camaro Z/28 |
| Bookmarks |
