Old 09-06-2018, 04:31 PM   #26
jbgroby
jbgroby's Avatar
Re: Cutting in Headlight relays.
I sure hope so.
jbgroby is offline   Reply With Quote
Old 09-07-2018, 08:03 PM   #27
jbgroby
jbgroby's Avatar
I wanted to wire in the new relay harness but will need to get a female connector for the truck harness wires. I have a tan and a green wire coming from the firewall and the new harness had a 3conductor. I suspect the black wire is the ground, but I'm not sure yet. If it is then I will simply put a ring connector on it and ground it to the rad support. Did anyone else in the group deal with this?
Jake
Old 09-07-2018, 08:48 PM   #28
karlbenz
Black is ground
2000 c3500 utility bed 7.4l 5sp manual old body style. Cab and chassis
1964 GMC K10 383cu in/sm465/twin stick np205
1965 Chevy C60
karlbenz is offline   Reply With Quote
Old 09-07-2018, 11:31 PM   #29
jbgroby
jbgroby's Avatar
Great, thanks, did you ground I to the rad support? White goes to tan and blue to green. I think I'll have to add some red wire so the relationship can reach the positive battery post. How did you attach to the battery?
Old 09-08-2018, 03:40 PM   #30
karlbenz
I grounded to the radiator support. Ran a hot wire to the battery
1965 Chevy C60
Old 09-09-2018, 08:52 AM   #31
jbgroby
jbgroby's Avatar
Great! and thank you. It's suppose to rain most of the day, so I'll run to home Depot for some red wire and get her hooked up today!.
Old 09-10-2018, 08:37 AM   #32
jbgroby
jbgroby's Avatar
Chapter 3, got everything connected, pulled the headlight switch and have high beams, but when I push the floor high beam switch and have no headlights t all. How can something so seemingly simply be so damn problematic. I'm ready to give up, at this point I'll need to adjust the beam so as not to blind anyone while driving for now, but DARN.
Any ideas kindly accepted - PLEASE.
Old 09-10-2018, 10:17 AM   #33
theastronaut
theastronaut's Avatar
Check for power and ground at the low beam relay. If the relay has power and is clicking then it's working and the problem is with the main power from the batterty/alt, the wires from the relay to the headlights.
theastronaut is offline   Reply With Quote
Old 09-11-2018, 12:08 PM   #34
rpmerf
rpmerf's Avatar
Trace it out.
Since the high beams work, we know you are getting power to the headlight switch, and your headlight grounds are good.
Do you have 12v coming out of the headlight switch?
Do you have appropriate power at each of the pins on the relay?
30 - battery (12v)
85 - ground
86 - low beam wire (should be the same as at the switch)
87 - output to head light
Do you have voltage at the headlight connector?
1970 C20 Custom Camper - 350, TH350
1997 GMC Suburban
1994 Acura Integra GSR
1987 Dodge Daytona Shelby Z
rpmerf is offline   Reply With Quote
Old 09-11-2018, 03:24 PM   #35
jbgroby
jbgroby's Avatar
Thanks,
I check it this week,
