#26 |
Re: Rebuilt engine lacking power
I wouldn’t be changing any springs until I power timed it like in the instructions.
Then adjust your dizzy mechanical timing. Who knows, maybe your motor will like 16 or 18 initial. |
#27 |
Vacuum advance,,,,,
Not sure about yours but with my MSD, the vacuum advance was 20`. I had to make a bushing to limit the vac adv to 10. (AMC motor) Back to basics,,, as the engine speed increases, the timing must fire sooner and sooner to produce max power at ~TDC. Do you have an adjustable timing light? If yes, set the dial to 32 and as you rev the engine, see if the mark comes back to TDC at the balancer. Find out at what RPM your timing is at, 2000, 3000, 4000, etc |
#28 |
On your chart start with the left side.
I think those numbers are distributor numbers for different OEMs. Yours should be 31021. The different color springs for your dist are in the next column, gold, silver & black. In the curve start column it lists the rpm which the springs start to stretch & the mechanical timing advances. The gold springs start to stretch at 400 rpm & silver & black start at 600. (Why the Hell they would want the springs to advance at a speed lower than idle??? Go figure ![]() In the last column it tells you at what rpm the timing stops advancing with the color spring you're using. It's a trial & error procedure but completely doable. However it's harder on a gm engine with the limited degree scale of the pointer. It's better to set it up like a Ford w/ a simple pointer & a timing tape on the balancer. I know you must be confused by now! ![]() |
#29 |
![]() Join Date: Feb 2000
Sounds like I need to get a timing tape for the balancer and go from there. Also, the vacuum advance vacuum source on the carb is ported, so no vacuum at idle. Long weekend out of town coming up so won't be much progress after today. This stuff is new to me, never messed with adjustable vacuum advance or changing advance springs before, if you couldn't tell already. Thanks for the help!
'51 South Bend Model "9A" '56 Chevy 3600 NAPCO '74 Chevy Cheyenne Super K20-restored on 37's '72 GMC Sierra Custom K2500- in progress '08 GMC Envoy Denali '12 GMC Sierra 2500HD Denali '17 GMC Yukon XL VCCA member #58596 http://www.nohrco.com |
#30 |
![]() Join Date: Apr 2009
Timing tape is a good idea, If you can find an older timing light with the adjuster knob makes it easier.
Using the Advance Timing Light to Measure Total Timing The advance dial feature also allows you to check the total timing. Total timing is base timing added to the vacuum added advance or computer added advance. To calculate the total timing of your engine, rev the engine to 3,000 RPMs and maintain it there. Now, when you aim the timing light at the timing marks, you can no longer see them. Rotate the dial on the timing light until you see the timing mark begin to recede on the timing tab. The further you turn the dial, the closer the timing mark comes to the 0 degree mark. Advance the dial until the timing mark is sitting at 0 degrees and then look at the dial. The number you now see indicates total timing.
Desert |
#31 | |
read this, it will help you understand the ins and outs, http://www.superchevy.com/how-to/add...nition-timing/ |
#32 | |
#33 |
Once the throttle is advanced enough to uncover the port source, pretty much the same.
Another benefit of manifold vac advance is lowered risk of running off the cruise part of the carb while at idle. A symptom of being on the cruise part of carb at idle is the idle mix adjustment has little effect on idle speed. If you want to try manifold vacuum, tie in to the tree behind the carb that comes out of the intake. Be sure to plug the ported port during the experiment. Ported vs manifold shouldn't make any difference to your originally posted problem as when you are at or near WOT, vacuum advance is out of the picture due to near zero manifold vacuum. That's where your initial + mechanical fully takes over. |
#34 |
He doesn’t need to tee into anything, the blue cap under his choke linkage is manifold vacuum.
#35 |
driving is in my blood
That wasn't the point. The factory stock cam fit the application and works. You choose an aftermarket grind for more power, torque, efficiancy. Why choose a less efficiant and powerful design compared to a modern one when your already paying for a new cam and doing the work to put it in? Racing has literally nothing to do with it.
-78 c10 short/step: 388cid, M20, 5/5 drop, lots more. Playtoy and first vehicle. -98 c1500 x-cab: 5.7L, 17" rims, 5/6 drop, flowmaster, helper bags,NBS rear disk brakes. -02 Suburban 4x4: leveled front -CBR600F4i, CBR600RR, CBR1000RR, and standup skis DISCLAIMER: I cant spell for the life of me. |
#36 |
40+ year old lobe design or not, that MTC-1 Melling camshaft is proven and still works very well to this day. It is well suited for your application. The camshaft is not the problem and I would choose it over these modern fast ramp. lobe killing, noisy grinds of today.
#37 | ||
Anyway, enough about the cam, it is what it is and not changing. I had to order a timing tape for the balancer so waiting for that to arrive and then I can get back to determining what total timing is set at.
#38 |
Ok, So got the timing tapes finally, they don't last long but of course I had to reposition it a few times to get it in the right spot. My initial timing at idle is 16-degrees BTDC. At 2000 rpm with vacuum advance connected the tape read 22, so 38 total. I unplugged the vacuum advance and reran it at 2000 rpm and the tape read 15. So, 16 initial, 15 mechanical and 7 vacuum, total of 38. Then the tape flew off and wouldn't stay on. Right now the truck seems to respond and have more power on the road than before, especially at partial throttle. I'll see if I can get my hands on an advance timing light next.
#39 |
Yup!
You need a dial back light! All the numbers you got there don’t jive. Study this link (or ignore it) and learn about timing your motor. http://www.badasscars.com/index.cfm/...d=76/prd76.htm Or power time your motor like your instructions suggested. |
#40 | |
Chris |
#41 |
I have the distributor set at 16 BTDC at idle. The weights are free, not hung up or locked out in any fashion.
#42 |
At what idle rpm did you set your 16 degrees?
#43 |
Idle is set at 800 RPM.
#44 |
This is from the distributor instruction sheet on how to adjust the vacuum advance. This is where mine is set at currently.
#45 |
Here is what I do.
Measure it at idle, without the vac advance. Sounds like it comes up to ~16*. This is your base timing. With the vac advance still disconnected, measure it at ~3000 RPM (or whenever it stops advancing), it should read somewhere around 34*. No math, that is what it should read. This reading minus your base reading is what you get from mechanical. Plug the vacuum advance in. Whatever it reads minus what is was without the vacuum advance is what you are getting from the vacuum advance. So if you are getting 16* at idle without the advance and 22* at idle with the advance, the vac advance is adding 6*. I figured out my max vac advance by driving cold. When your engine is cold, your choke runs the engine rich, so you need less advance. Richer A/F mixture burns faster. I think I started with about 14* and backed it down to 12* because it was pinging. It's been running perfect this way for ~6 years. It does sound like you are not getting any mechanical advance.
1970 C20 Custom Camper - 350, TH350 1997 GMC Suburban 1994 Acura Integra GSR 1987 Dodge Daytona Shelby Z |
#46 |
You need to get the idle a little lower to set your initial. You don’t want to see any mechanical timing kicking in. That can happen at 800 rpm.
Was your 16 set with your timing tape or on the timing tab? |
#47 |
Timing tab, just by moving the distributor.
#48 |
I’ve never seen a timing tab that showed more than 12 degrees.
Where you just eyeballing the extra 4degrees? You got a pic of yours? |
#49 |
This is a picture of the timing tab I have, I found a NOS one to use. Goes to 16 BTDC
GM #3991436 https://paceperformance.com/i-513484...al-finish.html
#50 |
So it does.
Now the ultimate question! Is it accurate? Does zero on it align with the balancer mark when #1 is at true tdc? |
