09-21-2018, 12:25 PM | #26 | |
Re: Value with / without SPID on glovebox door
SPID is one thing, a build sheet even better because it shows everything. If you have both and year/truck correct this and that's, then there are no secrets.
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 Last edited by 71CHEVYSHORTBED402; 09-21-2018 at 05:30 PM. |
09-21-2018, 01:06 PM | #27 |
Based on the looks of your build sheet it appears as though it came from between the foam of the seat and the springs, were they usually put there or are there other hiding places that were specific to the building plant?
Also, was it possible to order a 307 or 350 with the heavier duty Turbo 400 automatic? Or is that exclusive to the 402 engine?
Ron 1972 Cheyenne Super 1/2 ton LWB 4x4 - Grapefruit Yellow / White |
09-21-2018, 01:15 PM | #28 | |
I believe a 350 can have a 400TH. Not sure about a 307. I'm no expert, seems the same would apply. Edit: Don't know why I never checked before, but I don't see a build sheet for my C20 Super. Maybe it's behind the seat. Do I know it's a 72 Super? Yep. The SPID matches up, but sure, it could be a repop or the door came off another truck......................But all evidence is the truck has never been restored, and it's a rust bucket (ha!). Every part imaginable matches up to a Super, including the what you call it fiber insulators that fit between the doors and fenders. A build sheet would add assurances. HA!, check that. The build sheet is on the back of the seat No way I'm pulling it out without removing the seat.
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 Last edited by 71CHEVYSHORTBED402; 09-21-2018 at 01:48 PM. |
09-21-2018, 05:02 PM | #29 | |
Go Pack Go!
I wouldn't waste my time trying to spend that kind of money buying a C-10 Super if it didn't have SPID or build sheet proof. |
09-21-2018, 06:50 PM | #30 |
You very well may be right. The C10s are going the way of the tri fives. Not a large margin of people want a restored original pickup. The LS transplanted trucks are becoming plentiful. It was just last week that a thread about disc brakes being an upgrade. By an overwhelming margin, most folks on here contended that discs rule. That is the great thing about these trucks, there is something for all of us. I wonder what the percentage is, of restored trucks that follow the Spid down to the letter. I am already in violation on mine. I have added a v8 and PS. surely the heat and air will even make it worth less or will it? My question to the OP is this.. Can you put a truck together just like that for 25K? If it suits you, go for it. They just keep climbing.
:My build thread http://67-72chevytrucks.com/vboard/s...d.php?t=807535 1972 K10 swb/1968 Camaro 350/4spd 1955 210 2 dr sedan/1998 RCSB Z71 |
