Old 03-13-2019, 11:27 PM   #26
cornerstone
cornerstone's Avatar
Re: L83 swap 72 C10
Originally Posted by f.flujan View Post
Cornerstone, did you need a high hump to fit the transmission
Hey... I don't really have a good answer on the need for sliders since I don't have any reference for them. I did need the high hump to cover the 6L80E.
Brian
1972 C10, "Loyd", LWB to SWB, 5.3, L83/6L80e, 4:11 Tru Trac, Air Ride, VA, DD, 20" Coys, 4 wheel disc, A quick LS swap turned into a 6 year frame off resto-mod.
cornerstone is offline   Reply With Quote
Old 03-17-2019, 09:13 AM   #27
Dmarkmc
Re: L83 swap 72 C10
Hey guys- great info on your thread. I’m doing an LT swap in a 70 Suburban. I really do not want to change the oil pan and I am trying to leave everything on my motor as stock as possible. Are you guys aware of any motor mounts out there that allow you to keep the stock pan on the motor? Thanks!
Dmarkmc is offline   Reply With Quote
Old 03-21-2019, 11:24 PM   #28
cornerstone
Re: L83 swap 72 C10
For Mark.
Brian
Old 03-22-2019, 08:58 AM   #29
f.flujan
Re: L83 swap 72 C10
I’m getting some motor mounts made to make these headers slip right in and keep the vacuum. Gentlemen named Jaime from Metaltek is making them.
f.flujan is offline   Reply With Quote
Old 03-22-2019, 08:59 AM   #30
f.flujan
Re: L83 swap 72 C10
Only bad thing is speed engineering don’t ship to California
Old 04-16-2019, 03:41 PM   #31
Dmarkmc
Re: L83 swap 72 C10
f.flugan - good move on the MetalTek mounts. I tried the DD Gliders and they left the motor way too high in the air and at a rediculous angle. I saw your post and have contacted Jaime to get the same mounts. Thanks for posting that! The DD's are going back!
Old 04-16-2019, 03:46 PM   #32
howell57
Re: L83 swap 72 C10
I'm waiting on Jaime Neibarger from Metaltek to start shipping. Getting motor mounts for L83 and trans mount for 6L60.
howell57 is offline   Reply With Quote
Old 04-16-2019, 04:47 PM   #33
howell57
Re: L83 swap 72 C10
Doing a L83 - 6l60 in a 72. The hump you talked about, is it one that you made or bought and if bought, who from?
TKX
Old 04-16-2019, 05:51 PM   #34
Dmarkmc
Re: L83 swap 72 C10
TKX
I got mine on EBAY - 67-72 high hump transmission cover - $99. Does not come with fasteners so I got this set (Retro-Motive GM Truck Body Bolts & U-nut Clips- 5/16" x 13/16" Long- 1/2" Hex- 20 pcs- #392) on Amazon that works really well. Has just the right number of fasteners.
I'm reasonably computer savvy but I can't figure out for the life of me how to copy the actual link to the Amazon page. Hope the above info helps.
Old 04-16-2019, 05:57 PM   #35
howell57
Re: L83 swap 72 C10
I have built several small blocks, but this engine is a whole new learning curve for me. I assumed with the Metaltek mounts that the engine would sit a little higher and you validated that a 72 C10 will need more room for the trans. Thanks!
Old 04-16-2019, 06:14 PM   #36
Dmarkmc
Re: L83 swap 72 C10
That's me. Old school iron block that takes about 3 wires to make it run. This LT swap has definitely been new territory and I'm learning something new every day. You will want to use the Holley 302 oil pan if you havent learned that already. I hated having to change the factory pan but it was the only way to do it right.
Old 04-18-2019, 04:28 PM   #37
Dmarkmc
Re: L83 swap 72 C10
Trying to figure out the gas pedal situation for a 70 Suburban L83 swap. My harness is wired for the 2015 factory truck pedal but I sure don't see a very good way to mount the pedal. What's everyone doing for these?
Old 04-22-2019, 07:29 PM   #38
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
Re: L83 swap 72 C10
I used this.
http://67-72chevytrucks.com/vboard/s...d.php?t=651123
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 04-23-2019, 12:15 PM   #39
First c10
First c10's Avatar
Re: L83 swap 72 C10
Mine is from a 2008.
I used the original plastic pedal with modifications.
I still have to bend the pedal rod to make it straight with the brake pedal.
1956 Chevy Bel Air 2 door
1956 Chevy 210 4 Door
1970 K20 LWB project the Hulk build w/Supercharged 4.8L-ly2/4L60E HULK BUILD
1970 C10 Yellow/White Deluxe LWB w/ 5.3L-LC9/6L80E
1968 K10 LWB Dark green my son calls it "THE HULK Jr"HULK JR *SOLD*
GO GO!!!
First c10 is offline   Reply With Quote
Old 04-29-2019, 12:00 PM   #40
howell57
Re: L83 swap 72 C10
Using a Holley 302-20 oil pan for my L83 and would like to know if you have heard of a Fel-Pro oil pan gasket for this engine.
Old 04-29-2019, 12:57 PM   #41
Metaltekman
Metaltekman's Avatar
Re: L83 swap 72 C10
You have use the OEM style gasket sealer, it is offered in many brands. This engine has the pick up tube built into the pan with a seal on it. The pan and engine have machined flat surfaces, a gasket between there would allow extra space at the pick up tube seal.
Metaltekman is offline   Reply With Quote
Old 04-29-2019, 03:35 PM   #42
howell57
Re: L83 swap 72 C10
Took Holley pan to a parts store and there is one that matches up at every point except it is not long enough. It had the two holes for the oil.
Anyway, I bought the rtv to put the pan on and the other two lock tight and thread seal as per Holley's instruction sheet.
Old 12-24-2019, 01:10 PM   #43
dert428
Re: L83 swap 72 C10
https://www.ebay.com/itm/2010-2015-C...72.m2749.l2649
I used a pedal from a SS Camaro 10-15. about 50 dollars off ebay. Its a straight pedal and makes it easier to mount. The wiring is slightly different though. Just have to move some wires at the pedal connector.
dert428 is offline   Reply With Quote
Old 02-17-2020, 05:40 PM   #44
outlaw 3454
outlaw 3454's Avatar
Re: L83 swap 72 C10
wanna have some real fun, yes i am putting one in a 68 c10 right now, but mine will have a 6 speed manual, i had a lt1 old style 97 model and am converting the lt 756 to ls t56 and put it behind the l83,
thanks to jason at texas drivetrain performance, psi wiring harness, gas pedal and a few other parts, speed engineering headers and mounts,
got a ways to go but soon will be driving
outlaw 3454 is offline   Reply With Quote
Old 02-17-2020, 08:36 PM   #45
87chevy.com
BMW & ASE Master Certified
87chevy.com's Avatar
Re: L83 swap 72 C10
Nope, just rtv
1987 Silverado - L83 5.3 w/ 6L80e ,A/C,P/W,P/L,TILT, HID projectors, Wilwood C-10 Pro Spindles w/ 2018 silverado front brakes & C-5 Corvette Rear Disc Brakes
1999 BMW 528i - 5.7 LS1 w/ 4l60e, Ford 8.8 IRS w31 spline posi & FX-r projector retrofit
New project: 2006 BMW x5 6cyl AWD to L83 6l80e 4wd to 2WD / RWD
A poor man buy's it twice
finally got my domain name back, 87chevy.com.... site rework in progress
87chevy.com is offline   Reply With Quote
Old 02-20-2020, 01:06 PM   #46
cornerstone
Re: L83 swap 72 C10
Can you tell me the actual changes You made? I can’t find what my 14 L83 requires to make my 13 Malibu pedal work.
Brian
Old 02-24-2020, 12:09 AM   #47
87chevy.com
Re: L83 swap 72 C10
Just rewire pedal, that's it.. get the 2 diagrams and match em up. I havnt used the malibu pedal yet so cant give pinouts on that one.
Clint
