10-11-2018, 04:46 PM | #26 | |
Re: Reading A/C gauge
http://67-72chevytrucks.com/vboard/s...d.php?t=698292 |
10-12-2018, 11:03 AM | #27 | |
You adjust the POA using temperature pressure table for the refrigerant used. You want the pressure to be such that the evaporator temperature is just about 32 degrees. For R12 temperature of 32 degrees the pressure is 30.1 For R134a temperature of 32 degrees the pressure is 27.8 If the evaporator pressure is less than the above figures the evaporator will freeze up, if the pressure is more (such as in your case) the evaporator will not be cold enough to provide cooling. The POA valve is isolated from atmospheric pressure so you compensate for altitude on your gauge which is affected by altitude. |
10-12-2018, 11:19 AM | #28 | |
Unplugging the blower motor puts a high refrigerant load on the evaporator without airflow across it, the POA valve should not allow the pressure to fall below the POA set point. If it were to fall below the set point the evaporator would freeze the condensation in the air forming ice on the outside of it which would prevent air from flowing through the evaporator which would cause a no cooling condition. The factory POA setting is not 32, it is as I previously explained. Heater core bleeding means the core is getting hot water when in the AC mode which hinders vent temperatures. Test the hot water valve or pinch off the heater hose. This is not your problem at this point. Spraying water on the condenser is a test for condenser capacity. Your high side pressure is normal so this test is not necessary. High side pressure does not affect low side pressure in a POA valve system with a properly functioning expansion valve. Your expansion valve at this point does not seem to be a problem. |
10-12-2018, 11:22 AM | #29 |
I have assumed you know how much refrigerant is in the system...
When was it charged and what type of refrigerant? How much refrigerant is in the system? What does the sight glass look like, nothing, bubbles or clear. Or bubbles then clears up with rpm increase. |
10-13-2018, 05:22 AM | #30 | |
