Old 11-21-2018, 02:44 AM   #26
MiraclePieCo
MiraclePieCo's Avatar
Re: mustang vs camaro gas ank
Originally Posted by mick53 View Post
What I don't understand is where do you put the spare tire? I'm not leaving my truck on the side of the road for lack of a spare. Lots of people out there with trailers driving by. I believe in some states you are required to have a spare.
This "spare" has served me well; compact in size and quick to install. I've used it about four times. In a couple of cases it's worked so well that I never bothered to do a "real" repair. And have you ever pulled your spare out only to find it flat? That will never happen with this - seals AND inflates:
1951 Chevy Panel Truck
MiraclePieCo is offline   Reply With Quote
Old 11-21-2018, 02:48 AM   #27
MiraclePieCo
You could also use one of these spare tire mounts on the INSIDE of your box:
Old 11-21-2018, 02:58 AM   #28
layinrocker65
layinrocker65's Avatar
A lot of new cars don’t even come with spares. Just a pump and fix a flat
‘53 GMC COE stock
‘53 Chevy 3100 LSA/TR6060 http://67-72chevytrucks.com/vboard/s....php?t=805949‘
'70 Chevy C10 LWB 350/sm465
‘74 Chevy C10 SWB 5.3/4L80e, Vintage Air, Dakota Digital, US Mags
layinrocker65 is offline   Reply With Quote
Old 11-21-2018, 10:46 PM   #29
mick53
Originally Posted by Matt_50 View Post
I'm going with mine mounted on side of bed. It's part of the look I want, that and wood bed rails on top too.
I can't decide on the fender mount. I've got time. I like the wood bed rails.
mick53 is offline   Reply With Quote
Old 06-27-2019, 08:46 PM   #30
Matt_50
Well if I want to start my truck up next month I need a fuel tank filler, cap, and a way to vent it.
What suggestions do you guys have? I'm wanting a flush mount bed fill. And I need a way to vent it. What have you guys done for your mustang tanks?
1950 Build
Matt_50 is offline   Reply With Quote
Old 06-30-2019, 09:32 PM   #31
Matt_50
I got a little adventurous.my welding isn't great but I figured I'd try it before I bought a kit.
I grabbed the factory filler neck. I needed a filler with cap that wasn't more than 2.5 inches. The factory cap is pretty lowfile, so I measured it and decided to cut it down.
The factory filler also had a tube coming off of it and I cut it off, drilled a hole in my "new" filler, and welded it on at an upward angle. Very ugly weld but it works!!
I grabbed a couple pieces of wood and laid it across the bed. The wood isn't as thick as it needs to be, and the bed isn't sitting on the rubber pieces yet either.
I've seen a couple flush doors that I could use in the wood and I think I'm good.
Thought? Suggestions? I'm not sure where I need to run my vent line... should I put a breather on the end too?
1950 Build
Old 12-30-2019, 11:58 PM   #32
mobileortho
mobileortho's Avatar
I went with a stang tank as well. I had been using a 67-72 rear conversion tank but after flipping the axle it simply hung too low for my comfort. This one fits perfectly in the 3600 frame rails after trimming off the bottom of the frame.
Robert C.
1950 3600
3600 re-do, shortening it up
If it's true what they say, "You learn from your mistakes,"
I'm a Genius in the making.
mobileortho is offline   Reply With Quote
