Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 99-06 GMT800 Chevy and GMC Message Board > 99-06 Projects and Builds
Old 11-10-2018, 02:05 PM   #1
hatzie
Moderator
hatzie's Avatar
Hatzies 2005 2500HD
In July of this year I flew to Sacramento CA and bought a rust free 2005 Silverado LS 2500HD extended cab 6'6" bed with the 6.0, 4L80E, NP263HD, 4.10 gears.
The shipper delivered it to me at their terminal in August.
I ran the VIN on CompNine and they claim the following equpment was on this rig when it left the GM plant.
1SB SALES PACKAGE SALES PKG(1SB)
1SZ PACKAGE OPTION- (1SZ)
59U EXTERIOR COLOR,PRIMARY,FINE SILVER BIRCH MET (59U)
69D TRIM COMBINATION CLOTH,VERY DARK PEWTER (69D) Original
69I INTERIOR TRIM COLOR,VERY DARK PEWTER (69I)
6GK SPRING COMPTR SELECT FRT LH SUSP(6GK)
7GK SPRING COMPTR SELECT FRT RH SUSP(7GK)
A31 WINDOW,POWER OPERATED,ALL DOORS PWR WINDOWS(A31)
AE7 SEAT,FRT SPLIT,EASY ENTRY EASY ENTRY SPLIT F/SEAT(AE7)
AG1 ADJUSTER FRT ST POWER, MULTI-DIRECTIONAL, DRIVER MULTI-DIRECTIONAL PWR D/SEAT ADJR(AG1)
AJ1 GLASS,DEEP TINT(REAR SIDE WINDOWS AND REAR DOOR WINDOW) DEEP TINTED GLS(AJ1)
AM7 SEAT,REAR FOLDING RR FLDG ST(AM7)
AU0 LOCK CONTROL,REMOTE ENTRY(KEYLESS ENTRY SYSTEM) REMOTE ENTRY LK CONT(AU0)
AU3 LOCK,SIDE DOOR,ELECTRIC ELEC S/D LK(AU3)
B30 CARPET,FLOOR AND WHEELHOUSE FLR CPT(B30)
B32 COVERING,FLOOR MATS,FRONT AUXILIARY FRT AUX FLR MATS(B32)
B33 COVERING,FLOOR MATS,REAR AUXILIARY RR AUX FLR MATS(B33)
B71 ORNAMENTATION,EXTERIOR,WHEEL OPENING MOLDING(BLACK) W/H MLDG(B71)
B85 ORNAMENTATION,EXTERIOR,BELT REVEAL MOLDING BELT RVL MLDG(B85)
C49 DEFOGGER,REAR WINDOW,ELECTRIC ELEC RR WDO DEFG(C49)
C6W GVW RATING(9200 LBS) 9200 LB GVWR(C6W)
CJ2 HVAC SYSTEM AIR CONDITIONER FRT, AUTO TEMP CONT, AUX TEMP CONT A/C FRT AUTO/AUX CONT(CJ2)
DF5 MIRROR,INSIDE,REARVIEW,LT SENSITIVE,COMPASS,O/S TEMP DISPLAY I/S REARVIEW MIR W/COMPASS(DF5)
DK7 CONSOLE ROOF INTERIOR,CUSTOM,COMPASS & OUTSIDE TEMP RF CNSL(DK7)
DL3 MIRROR O/S LH & RH, REMOTE CONTROL, ELECTRIC, HEATED POWER FOLDING, TURN SIG IND, LT SENSITIVE, COLOR ELEC HEATED O/S MIR(DL3)
E63 BODY EQUIPMENT,FLEETSIDE PICKUP BOX FLEETSIDE PUBX(E63)
EVA TEST DVT, EVAP EMISSION REQUIREMENT EVAP EMISSIONS REQUIRED(EVA)
FT2 ARM TORS BAR SPRING ADJ (FT2) ARM LH TORS BAR SPR ADJ(FT2)
FT3 ARM TORS BAR SPRING ADJ (FT3) ARM RH TORS BAR SPR ADJ(FT3)
G80 AXLE,REAR,POSITRACTION,LIMITED SLIP POSITRACTION L/SLIP R/AXL(G80)
GMC PLANT CODE PONTIAC, MI, GM T&B PONTIAC,MI GM T&B ASSEMBLY PLANT(GMC)
GT5 AXLE,REAR,4.10 RATIO 4.10R(GT5)
HVY IDENTIFICATION 2 INCH BODY RAISE, H.D. MODEL TWO INCH BODY RAISE I.D.(HVY)
JH6 BRAKE HYD POWER, 4 WHL DISC, 9,900 LBS BRK HYD PWR DISC(JH6)
K34 CRUISE CONTROL,AUTOMATIC,ELECTRONIC CRCONT(K34)
K47 AIR CLEANER HIGH CAPACITY HI CAPACITY A/CL(K47)
K68 GENERATOR,105 AMPERE 105 AMP(K68)
KC4 COOLING SYSTEM,ENGINE OIL ENG OIL CLG(KC4)
KNP COOLING SYSTEM,TRANSMISSION,HEAVY DUTY HVY DUTY TRANS CLG SYS(KNP)
KUP THROTTLE CONTROL VARIABLE SPEED (ELECTRONIC) ELECTRONIC THROTTLE CONTROL(KUP)
LQ4 ENGINE GAS, 8 CYL, 6.0L, MFI 6.0U(LQ4)
MT1 TRANSMISSION,AUTO,4-SPD,THM-R2(4L80-E) 4-SPD A/TRANS(MT1)
NA4 EMISSION SYSTEM,ABOVE 8500 LB GVW EMIS SYS(ABOVE 8500 LB GVW)(NA4)
NC1 EMISSION SYSTEM CALIFORNIA, LEV CALIF EMIS LEV(NC1)
NP1 TRANSFER CASE,ELECTRONIC SHIFT,TWO SPEED ELEK SHFT TRFER CASE(NP1)
NP5 STEERING WHEEL,LEATHER WRAPPED LEATHER WRAPPED STRG WHL(NP5)
NZZ PACKAGE,OFF ROAD SKID PLATE,SPORT SKID PLT PKG(NZZ)
PY0 WHEEL,16 X 6.5,ALUMINUM ALUM WHL(PY0)
QIW TIRE ALL LT245/75R16/E BW R/PE ST TL OOR 120Q TIRE(QIW)
R9Z CONTROL - SALES ITEM NO.100
SAF LOCK SPARE TIRE, HOIST SHAFT SPARE TIRE LOCK HOIST SHF(SAF)
SLM SALES PROCESSING - STOCK ORDERS
T96 LAMP,FRONT FOG FRT FOG LP(T96)
TR3 GRILLE RADIATOR, BODY COLOR, W/CHROME EMBLEM BODY COLOR GRILLE W/CHROME EMB(TR3)
UB0 RADIO AM/FM STEREO,SEEK/SCAN,CD,AUTO TONE,DATA RAD STEREO W/CD & DATA RAD(UB0)
UK3 ELECTRONIC SYSTEM,ACCESSORY CONTROL ELEK ACSRY CONT SYS(UK3)
UQ3 SPEAKER SYSTEM,PERFORMANCE ENHANCED AUDIO ENHANCED SPKR SYS(UQ3)
UY2 PROVISIONS, CAMPER WIRING HARNESS CAMPER & 5TH WHEEL WIRING HARNESS(UY2)
V73 VEHICLE STATEMENT - US/CANADA US/CANADA VEHICLE STATEMENT(V73)
VB3 BUMPER,REAR STEP,INCLUDES IMPACT STRIP(CHROME) CHROME STEP BPR(VB3)
VG3 STRIP,FRONT BUMPER IMPACT FRT BPR IMP STR(VG3)
VG8 LABEL,NOTICE TO BUYER NOTICE TO BUYER LABEL(VG8)
VP6 NOISE LEVEL CONTROL NOISE LVL CONT(VP6)
VR4 TRAILER HITCH(WEIGHT DISTRIBUTING PLATFORM) EQLZR HITCH(VR4)
VXS VEHICLE - COMPLETE
X88 CONVERSION CHEVROLET CHEVROLET(X88)
XGK TIRE FRONT LT245/75R16/E BL R/PE ST OOR(9591214) TIRE(XGK)
YD3 AXLE FRONT (BASE EQUIP) FOR SCHEDULING GVW PLATE FRT AXLE(YD3)
YD6 SPRING,REAR(BASE EQUIPMENT) RR SPRING(YD6)
YE9 CONVENIENCE PKG COMFORT & DECOR LEVEL #3 COMFORT & CONVENIENCE PKG #3(YE9)
YF5 CALIFORNIA EMISSION CERTIFICATION CALIFORNIA EMIS CERTIFICATION(YF5)
YGK TIRE REAR LT245/75R16/E BL R/PE ST OOR(9591214) TIRE(YGK)
Z82 TRAILERING PACKAGE(SPECIAL)(REESE TYPE HITCH) PROVISION FOR HD TRAILER EQUIP(Z82)
Z85 CHASSIS PACKAGE,INCREASED CAPACITY CHAS PKG(Z85)
ZHH TIRE SPARE LT245/75R16/E BL R/PE ST ALS(9591207) SPARE TIRE(ZHH)
ZY1 COLOR COMBINATION SOLID SOLID PAINT COMBO(ZY1)
I usually make OEM-Plus mods to my vehicles. The goal is that they look like GM could've done it and my work is clean enough to be factory or dealership installed options.
***EDIT****
You can likely get your local GM dealer to print a build sheet if you ask nicely.
You can also get a PDF build sheet from GM for your T800 in your email as well.
It took several days to get an answer. It's free so even if it takes em 2-3 weeks that ain't bad...
---------------form email---------------
Email to: socialmedia@gm.com
Subject: Build sheet request
Hello,
I read that I could request a build sheet on the 67-72 Chevy Truck Forums.
I'm hoping you can provide me with a build sheet for My GM Light Truck.
Year, Make, Model, VIN: xxxxxxxxxxxxxxxxx
Thank you,
My Name
1959 M35A2 LDT465-1D SOLD
1967 Dodge W200 B383, NP420/NP201 SOLD
1969 Dodge Polara 500 B383, A833 SOLD
1972 Ford F250 FE390, NP435/NP205 SOLD
1976 Chevy K20, 6.5L, NV4500/NP208 SOLD
1986 M1008 CUCV SOLD
2000 GMC C2500, TD6.5L, NV4500
2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263
2009 Impala SS LS4 V8
RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...Please include at least the year and model in your threads. It'll be easier to answer your questions.
And please let us know if and how your repairs were successful.
