Old 11-19-2018, 03:12 PM   #26
NewBayColony
NewBayColony's Avatar
Re: 3 Speed Overdrive
Thanks for the responses. Now I have another question. Is the linkage available for the 4 bolt that works on a 72?
This may sound odd but I kinda want the non sincro first. i had plenty of them plus I've driven tractor trailer for 40 years. One non sincro gear is a breeze.
NewBayColony is offline   Reply With Quote
Old 11-19-2018, 03:17 PM   #27
57Suburb
57Suburb's Avatar
This may sound odd but I kinda want the non sincro first. i had plenty of them plus I've driven tractor trailer for 40 years. One non sincere gear is a breeze.
LOL, I'll have some linkage available soon.
1972 C30 Grain Hauler, 350/400
1967 1500 GMC Stepside SWB, In Transformation Process
1967 RS/SS Camaro 350/TKO600
57Suburb is offline   Reply With Quote
Old 11-19-2018, 03:27 PM   #28
NewBayColony
Wow, cool.
Old 11-23-2018, 11:59 AM   #29
NewBayColony
OK 57 Suburb, I bought the tranny, will you have the linkage? Thanks, Jeff
72 C20 292 3OTT
77 GMC 2500 4x4 Longstepper 350 4sp
50 3100 ex Airforce/Town of Mendon fire truck
72 GMC 1500 2wd short stepside 250 4sp
78 GMC 2500 4x Longstepper 292 4sp
54 6400 Chevy 5 window 4 sp 2sp vac rear end Shell oil truck/dump truck (Norman)
Old 11-23-2018, 04:42 PM   #30
57Suburb
57Suburb's Avatar
Yes, I'm about ready to pull the old motor/tranny. Was hoping to get it done this weekend, but some things have come up, so might be a week or two.
Old 11-23-2018, 06:05 PM   #31
NewBayColony
Don't worry about the time. Just happy to know you have the linkage. It's gonna be awhile till I can install everything anyway. I just wanted to let you know what was up. Hope you had a good Thanksgiving. Thanks, Jeff
72 C20 292 3OTT
Old 12-26-2018, 03:03 PM   #32
NewBayColony
Hello 57Suburb. Hope you had a great Christmas. Just wondering if you had a chance to do anything about that linkage for the 4 bolt Muncie 319? Thanks, Jeff
72 C20 292 3OTT
Old 12-26-2018, 03:35 PM   #33
geezer#99
geezer#99's Avatar
Did you get a bellhousing too?
Bearing retainer is bigger on a non synchro trans.
geezer#99 is online now   Reply With Quote
Old 12-26-2018, 05:38 PM   #34
57Suburb
57Suburb's Avatar
In San Antonio right now for a bowl game. Hoping to get something done when I get back.
Old 12-27-2018, 01:36 AM   #35
NewBayColony
I did not get the bell housing. Didn't realize I needed it. The guy I bought the transmission from has one. Is the throw out bearing fork different? Thanks!
72 C20 292 3OTT
Old 12-27-2018, 01:38 AM   #36
NewBayColony
Not a problem. I just wanted to know if I needed to start looking somewhere else. Thanks!
72 C20 292 3OTT
Old 12-27-2018, 10:46 AM   #37
geezer#99
geezer#99's Avatar
It’s the transmission bearing retainer that’s a different size.
The older trans has one that is about 5 1/8 inches in diameter.
Your present tranny likely has one that is about 4 7/8 inches.
The bearing retainer fits snugly into the big hole in the bell housing.
Easy to measure the o/d tranny.
You might need the other bell housing.
Old 12-27-2018, 11:02 AM   #38
NewBayColony
Got it! Thanks.
72 C20 292 3OTT
Old 12-27-2018, 11:51 AM   #39
geezer#99
geezer#99's Avatar
Another thought!
The other bellhousing might not work with your present flywheel/clutch assembly.
There’s big and small ones.
Something else to keep in mind.
Old 12-27-2018, 04:24 PM   #40
weim55
The 4 bolt 3 speed was produced with both sizes of input retainer. No problem if yours is not a match for your bellhousing, used replacement should be an easy locate. Both are very common. Your '72 should have the larger diameter bellhousing input retainer hole and likely your 3 speed OD will have the smaller dia. input retainer. Another option is Novak or Advance Adaptor sells a simple sleeve to make up the difference.
Steve weim55 Colorado
weim55 is offline   Reply With Quote
Old 12-28-2018, 01:07 PM   #41
NewBayColony
Thanks Steve. I'm in Fort Collins right now. When I get home I'll measure the overdrive transmission. The guy that I bought it from has the bell housing along with the clutch, pressure plate and flywheel. It was supposed to come with the tranny but I didn't think I would need it so I figured I would save on shipping by not taking it. I just texted him and he still has everything.
By the way, nice state you got here.
72 C20 292 3OTT
