11-27-2018, 04:11 PM | #26 | |
Re: Stupid Question about placing engine mounts
Hi guys. Sorry I didn’t see this thread til now. I was surprised to see a pic of my chassis and garage!
Funny I saw it today because I was JUST fiddling with the trans cover last night. We had to switch to the factory four speed trans cover instead of my stock three speed cover to allow for the larger size of the 4l85e. When we installed the adhesive heat barrier on the floor over a year ago we didn’t fill the (approx.) 4”x4” shifter hole - DOH! So yesterday I cut and carefully removed about a 1/2” of the barrier around the hole perimeter and instead of welding in a cover I will use panel adhesive to patch it, cover it with the same barrier on top and some rattle can bed protector on the bottom. PS: Anyone know if the trans cover was fastened to the cab floor with threaded speed clips or just sheet metal screws? Quote:
'55 Big Window Shortbed, Drive-It-&-Work-On-It slid down the "slippery slope" to a Frame-Off Rodstoration! LQ4/4l85e/C4 IFS/Mustang 8.8 rearend w/3.73's Dan's '55 Big Window "Build" - Well, Kinda! Last edited by Dan in Pasadena; 11-27-2018 at 04:22 PM. |
11-28-2018, 12:47 AM | #27 |
11-29-2018, 03:26 PM | #28 |
Read in its entirety. Thanks.
11-29-2018, 03:39 PM | #29 |
hope it helped you figure out what you will do.
post up a few pics when you get things started. |
12-03-2018, 10:58 PM | #30 |
I noticed several posts regarding engine-trans inclination front to rear. One trick I have discovered is that it's better to have your engine too far down in the rear because you can always add a spacer under your trans mount to shim it up higher. If it's too high to begin with, there's no way to lower it.
1951 Chevy Panel Truck |
