#26 |
At the body shop.
Re: Build front suspension before or after mounting the engine?
Always figured 1 coil equals 2 inches
2 coils 4 inches. If your only going 4 in the rear I would not cut a coil with your current 2.5 spindle. Or... clip a coil and go down 6 out back. 👀👀
" That didnt make it any newer " " Dont antique the equipment " |
#27 | |
![]() Join Date: Dec 2013
![]() Larry if you read this you cost me a bucket full of money ! ![]() pic is GR8-68's truck
![]() 1967 Factory short bed - Old school '71 - 350 / 4bolt / 487 heads / Edelbrock C3BX Muncie M-22 4 speed / Hurst Comp plus Factory 12 bolt posi 3.73 / 255-70-15 Smoothed firewall / Factory cowl induction Power disc brakes / power steering / 3.5-5" drop |
#28 | |
![]() Join Date: Feb 2009
If the stock height coils work toward my 4" & 2.5" goal then I'm good to use them. Hopefully I won't be disappointed I didn't drop it further ![]()
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
#29 | |
I'll let you know how mine sits later today , providing parts arrive (no mail delivery here today ) Dropped in the engine and bell housing , Cut 1 coil off stock springs and using 2 1/2 drop spindles with new Moog ball joints . My other 67 short bed frame is only getting the front springs cut 1 coil and I'll be taking the 4" rear springs off this frame to use on the other frame and changing them to 5 " with a 1 inch block on this frame . should be interesting to see the difference between them side by side . ![]()
![]() 1967 Factory short bed - Old school '71 - 350 / 4bolt / 487 heads / Edelbrock C3BX Muncie M-22 4 speed / Hurst Comp plus Factory 12 bolt posi 3.73 / 255-70-15 Smoothed firewall / Factory cowl induction Power disc brakes / power steering / 3.5-5" drop Last edited by Grumpy old man; 12-05-2018 at 09:31 AM. |
#30 |
Nice Grumps. Looks like energy suspension for your sway bar. I'm using the same, and their mount for a 400TH. What's your drive train?
#31 |
'71 truck 350 4 bolt to a stock 67 bell housing to a Muncie M22 Rock crusher to a custom drive shaft to a stock 12 bolt 3.73 factory posi to 29 x 15.5 x 15 Mt tires on the rear . I'm building this truck the way we would have done it in the early 70's .
#32 | |
#33 |
At the body shop.
I'm new to the 67-72 side of these trucks, been a squarebody guy for 20+ years.
I've always clipped 2 coils and flipped the back. Always sat right by my standards, looks and sits like a 4-6 drop. That's where I came by the 1 coil is 2" theory.
