01-01-2019, 10:08 PM | #26 | |
Re: Problems with reman Q-Jet: round two
01-02-2019, 12:22 AM | #27 |
01-02-2019, 07:53 AM | #28 |
01-02-2019, 09:53 PM | #29 | |
01-03-2019, 10:49 PM | #30 | |
01-04-2019, 10:02 AM | #31 |
[QUOTE=SilveradoDude;8418206]How do I check the secondaries to see if they are hanging?[/QUOTE
Just look at your linkage and watch the secondary linkage to see if it is returning all the way. I have had secondaries get hung up on the intake manifold or the gasket and not close all the way. The linkage itself can get a little sticky too. Is that thing still idling high? If you get those throttle plates closed up tight and it still idles high it must have a vacuum leak somewhere. I would still try the ported vacuum as a work around.
76 Chevy K20 76 GMC K15 77 Chevy C10 77 Chevy K10 |
01-04-2019, 10:31 PM | #32 |
In the third picture I posted I’m pointing the blade of a small screwdriver at the part of the linkage on the drivers side that should be touching the end of the curb idle screw when the engine is warm and is completely off the fast idle cam. If they don’t touch, you have no ability to adjust the idle speed. Is that the case, and does the idle increase when you turn that screw clockwise and decrease when you turn it counter clockwise?
01-05-2019, 01:03 AM | #33 | |
Good luck to you w/your Q Jet. |
01-05-2019, 11:47 AM | #34 | |
01-05-2019, 12:47 PM | #35 |
I am very confused. The fast idle cam is on the passenger side. The screw to adjust it is behind the choke housing, below the front choke pull off and the fuel line. The curb idle screw is on the opposite side, inboard of where you hook up the throttle linkage and towards the front of the carb. They are two different screws. The curb idle screw never touches the fast idle cam and is on the opposite side. I’m trying to be sure we are talking about the same thing.
01-05-2019, 01:11 PM | #36 |
Try this pic
Desert |
01-05-2019, 01:16 PM | #37 |
Desert |
01-05-2019, 02:42 PM | #38 | |
01-05-2019, 06:44 PM | #39 |
I too was unable to lower my idle even when the curb idle screw was not touching the cam. Turned out it was the electric fuel pump (I have a '98 Vortec block so no mechanical pump) over pressuring the float. I replaced the pump and solved the idle problem. Could your fuel pump be doing the same or is the problem with the float level?
01-05-2019, 07:24 PM | #40 | |
01-06-2019, 06:59 PM | #41 |
Ok I think I have her running pretty good right now. Here is what I did and here are the specs.
I dealt with any and all vacuum leaks (nothing big here) I ran the vacuum advance from the rear T And I adjusted the fast idle cam back up as it was running a little low. I adjusted the timing back to where it was. Timing: 6 degrees BTC from 4 fast idle cam: adjusted half a turn clockwise RPM in P is low 700's RPM in drive mid 500's Solid 15 inches vacuum reading No smoke, no rough idle, no dieseling The last adjustment that I have left is the transmission kickdown. I have been having trouble depressing that button for the cable. |
01-08-2019, 05:27 AM | #42 |
Once the engine is warmed up, if you set your timing at about 12 btdc, your engine will be way happier, it will increase your idle vacuum, and be much more responsive, and get better mpg. Then with the engine warm, fine tune your idle mixture screws with a vacuum gauge hooked up to manifold vacuum, adjust to untill you get the highest vacuum reading.
77 k10 winter beater build http://67-72chevytrucks.com/vboard/s...d.php?t=716884 85 GMC short fleet budget build http://67-72chevytrucks.com/vboard/s...d.php?t=714222 80 C10 stepside build http://67-72chevytrucks.com/vboard/s...d.php?t=693848 |
