#26 |
thanks guys, i figured out that i need to go with this bracket, if anyone has one laying around and willing to sell, let me know, thank you, Nate
#27 |
Nate, in your pic, the 2 outer brackets are alternator brackets(right one bolts to front of exhaust manifold), the 2nd from the left is a lower p/s cradle bracket for long water pump, the 3rd bracket is an early p/s cradle bracket that will not work on 4-bolt main 350's with the larger damper. hope this helps. The set on the "green barrel" is what you need, usually go for at least $20 and up..ebay, here, etc I'd sell you some if I had them, sorry Greg
67 3/4 4x4 402,a/t,flat bed 98 GMC Sierra swb daily driver 87 burb parting out. 68 1/2 chevy, 350/350, 71 gmc frame, kid's beater 69 1ton 396-4sp, dump 69 swb stepside 396/400th current frameup 67 swb 454/400th rebuilding now, oldest boy just rolled it 99,HD, Road King Classic Colwich Ks |
#28 |
thanks for the info greg, that's why i come to the board, for the knowledge of others.
#29 |
Howzit?!?
About the Pic...
Tx Firefighter,
Should you check about royalties from your Pic? ![]()
Jason Hawaiian-J 70 Longbed, 307, Edelbrock Carb 1404, Edelbrock Intake 2101, Dual Roller Timing chain and gears, 214/214 cam, Comp Roller Rockers, dual Flowmasters. 1999 Chevy Tahoe 2004 Mini Cooper S 71 BMW 2002 - Sold |
