#26 |
![]() Join Date: Nov 2013
Re: In Lieu of the Hood Brace Pads?
My 67 hood is oil canned in one place on the driver side, an area about the size of a football. Otherwise it is straight and in great condition.
I thought about this piece from LMC..it looks like it has a couple of braces that might go right where I need them? Anyone used one....?
1967 C10 Step side 1968 C10 Step side 1970 Chevrolet K/5 Blazer 1972 Chevrolet K/5 Blazer ............. ![]() |
#27 |
Mr. Cheyenne
![]() ![]() Join Date: Jun 2020
It it wasn't for the gun that I would likely never use again, I'd get that 3M NVH Dampening Material product. That seems to be the real deal.
As for insulation kit - I'd be afraid it would make the engine bay hotter.
Richard '72 Chevy C10 Cheyenne *Super WHT/MED BRONZE/WHT SBC 350 | TH350 | LWB | AC | Buddy Seats Upgrades: Tilt | Front Sway Bar | Radio | Sliding Window | Bed Spare w/Lock Bed Rails | Full LEDs | Courtesy Lights | Tachometer | Glovebox Lock & Light | Head Light Relays | *Upgraded Fully Super Trim |
#28 |
To solve your problem of the pads falling out...consider putting the pads in and using the urethane to glue the pads to the braces, but not to the hood sheet metal. This way the hood skin and braces can shrink and contract at different rates and not be locked together. I would put in continuous beads between the braces and the pads, but not necessary, smaller globs or stitches would work well IMO.
Side Note: I mentioned earlier that the hood measured 71-1/2" wide at the back bottom...that was too wide when it came time to install it (painted of course, doh!). I compared it to another hood and it was 71-1/4" wide. I guess my hood had been flattened out at some point. There was no way to get the doors, cowl, fenders and hood to shim out properly at that width and I had to to get creative. I made two small "L" brackets that attached with the rear upper hinge bolts (one on each side) and used a piece of all-thread between them and tightened it until the hood was 71-1/4 wide. I left this apparatus in place as I did not want to over crank it and try to re-curve the hood for fear it would "snap" somewhere. Just another jury-rig that had to be done, but it worked really well. Down side is that you have to loosen the all-thread in order to adjust the hinges each time you need to move the hood to hinge alignment while trying to get the whole works to line -up well.
He who is without oil shall throw the first rod. Compressions 8.7:1 1972 C10 1976 C10 (parts truck) 1985 K20 |
#29 |
Mr. Cheyenne
I went with that 2 part 3M product and a gun. At least I got 10% off of the 3M Dampening Material after a searching google for a coupon. If anything, I'll give the gun to my brother for his shop.
Hopefully this stuff will also solve or at least lessen the hood jiggle - it's like a big bowl of jello LOL
#30 |
![]() Join Date: Dec 2013
![]() 1967 Factory short bed - Old school '71 - 350 / 4bolt / 487 heads / Edelbrock C3BX Muncie M-22 4 speed / Hurst Comp plus Factory 12 bolt posi 3.73 / 255-70-15 Smoothed firewall / Factory cowl induction Power disc brakes / power steering / 3.5-5" drop |
#31 | |
![]() Join Date: Jul 2015
When the engine is thumping I can see my hood go a bumpin! |
#32 |
![]() Join Date: Dec 2015
I know the thing being talked about is padding, but since the later trucks have a cross brace added, you kinda need to do that. My cheapskate solution is this, seems to work except where there is no padding on the existing braces. So I'm subscribed......
1968 Long Bed 2016 Honda Civic Coupe EX-T ticket magnet |
#33 |
![]() Join Date: Dec 1999
I use the original type foam padding. Weather strip adhesive is used to secure padding on the hood braces only. Purchased two pad brace kits so I had extra. The foam can be glued together and shaped to fill gaps that are loose. Will also be using a full hood pad.
Richard 1972 K10 Custom Deluxe SWB Fleetside My build https://67-72chevytrucks.com/vboard/...d.php?t=800746 |
#34 |
Mr. Cheyenne
well, now I am cooking with crisco!
#35 |
![]() Join Date: Jun 2005
Someone mentioned in the “cheap tricks” thread that they used garage door seal
70 C/10 SWB 402/TH400/3.73 "The Needy Beast" 200,000 Mile Club Disc Brake Club Owner installed options: Front Sway Bar Power Steering Power Brakes Cigar Lighter Courtesy Lights Deluxe Side Markers Wiper Delay Power windows Power Locks Sniper EFI 2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear |
#36 |
Mr. Cheyenne
This 3M setup was anything but cheap but darn easy to use. But I couldn't even tell you how many times I kept stuffing those pads back into place. Heck, I still stare at the passenger's ramhorn where one feel off and melted on top of it (pisses me off). That more or less tells me they weren't doing much for what they were intended for.
I bought two bottles and the middle braces I put a solid line from top to bottom. I removed all the other pads and put this 3M stuff in its place. I'd say 80~90% of jello jiggling is gone. Only from the center line out a few inches does it still jiggle. Which would make sense, since there isn't anything really to stabilize that area. I'd image that would take the additional braces in between the originals to solve that. Very happy with the 3M product. Anyone in the Austin area decides to do this, please hit me up to borrow the caulk gun, otherwise this thing would never be used again. If I was a dodgy (or my Dad), I'd just return it and say it didn't work or something LOL @Grumpy, thank you for posting about it.
#37 |
Yep that was me ... worked & lasted in my Blazer for 14 years & using the same on K20 build now. Can also put a little dob of gorilla snot (technically named weatherstrip adhesive) in spots if it tries to wiggle out over time on ends where brace is not as tight.
'72 C to K20 "Cannibalizer" http://67-72chevytrucks.com/vboard/s...32#post8653432 '85 K30 "Big Nassy" '06 3500 Duramax ...tow truck '06 Silverado SS...DD '06 C1500 WT...DD '07 Classic C1500 WT...DD Built & sold cause can't keep 'em all: '72 Blazer "The Bucket" http://67-72chevytrucks.com/vboard/s...d.php?t=433190 '55 Chevy straight axle gasser https://www.trifive.com/forums/showthread.php?t=173938 '69 Pro Street Chevelle http://www.chevelles.com/forums/showthread.php?t=332541 '86 M1031 CUCV http://67-72chevytrucks.com/vboard/s...d.php?t=553619 |
#38 | |
#39 |
Mr. Cheyenne
Hey D.B,
Here are a few photos for you. I am very happy with this stuff.
#40 |
#41 |
Mr. Cheyenne
Not a problem at all, I am very happy to help :-)
#42 |
![]() Join Date: Dec 2014
That gun will come in handy for any 3m product, I bought one for panel bond. I am going to try this out on my hood, thanks for the posts.
DAVE Edmonton, Alberta 1959 Apache 1967 K20 1968 C20 1970 C10 1972 GMC 2500 1981 C10 |
#43 |
Mr. Cheyenne
I gave the gun to my brother for his shop, he was pretty excited I gave it to him. He better not lose it when I need it again (in like 5 years) LOL
#44 |
I recently used the 3m 04274 on a 1968 hood.
I hung the hood using hooks and 2 pieces of conduit. I felt like that left the hood in a fairly natural state. I haven't started block sanding the other side yet, so I'll report back how it did. The last one I did was an aftermarket hood and it took a couple applications of featherfill G2 to get all the lows out. |
#45 |
#46 |
Mr. Cheyenne
that is great to hear DB - this 3M stuff has worked great and have had no ill effects!
