01-26-2019, 08:36 AM | #26 |
Re: Is 5.3 swap to much money and work?
As you can see from all the posts there are be pro's and cons for the old tech vs new 5.3-350 argument. Some guys love the old V-8 systems for their simplicity and retro feel.
When I came over from the dark blue side (Fo*D) to chevorlet 10 years ago I was really sold on the 350 being the greatest American V-8 ever made, especially for the money, power, and reliability that it produced. Chevy 350 parts are sold new and used Everywhere! I loved the 350 /700R4 set up in my 65 C10. Problem was I was getting about 12MPG around town. I was putting gas in it every other day. At the time I also had a late model 1500 Silverado 5.3 that was 1500 pounds heavier that the C10. I drove 50% of the work week in the 5.3 silverado and was amazed at the fuel usage difference as well as the power that this LS motor produced bone stock! So much so that i am sold on the LS technology- I never thought GM could build a better motor than the 350, I was wrong. I know many on here will strongly disagree with me but if you are building a daily driver go with the LS, keep the fuel injection on it as the was the GM engineers designed it to run. 4.8,5.3 6.0 any of those motors will produce more than enough power for a daily driver while getting much better MPG and reliability over the older motors. I still love the old big blocks and small blocks that the big three build for 50 years but for me it got old real fast paying at the pump. My current build is a 1951 Chevy with LS 5.3 and 4L60E- Its almost ready for the road. The bigger costs for an LS will be: your accessory brackets ($600) external fuel pump with plumbing ($350) and wiring harness and ECM reprogram for engine ($600) you can save some money using factory Accessory brackets but i did not have enough room to go this route. check out ICT billet IF you need brackets? they had some of the best prices at the time i purchased them. I also purchased a new harness (BP harness) rather than have someone rework the old one $300 vs $600. Had a great experience with those guys too. It ends up being one of those " well if I do this .. I might as well spend the $ and do this too thing ...Lol be careful going down that trail it can get very $$$ Like anything else there is a learning curve with the new LS technology- thats why a lot of guys are scared of it, But you can figure it out with all of the help on these forums- Good luck with whatever route you decide!!
current ride 1951 AD Chevy 5 window 2004 LS Gen 3 [/B] 1965 fleetside Sold |
01-26-2019, 01:13 PM | #27 |
Don't get me wrong: the 5.3 is a nice enough motor, but I don't notice that much difference in the mileage, and my 327 is about as reliable as an engine made by Man can get. My truck's drivetrain is engineered a unit, and replacing all of it would be far too expensive and involved even if I wanted to.
Yes, I know the 5.3 is a "327," but it ain't no 327! It hasn't the history, the reputation, or the dead-simple reliability.
'69 Longstep K-10: 327/SM465/T-221/Closed Knuckle Dana44/12-bolt. |
01-26-2019, 01:20 PM | #28 | |
At the body shop.
12-433-8 H-R in my 400 and is a ton of fun and totally street able
" That didnt make it any newer " " Dont antique the equipment " |
01-26-2019, 02:04 PM | #29 |
All about them K’s
I have big blocks small blocks and some ls stuff. The old stuff is cool and is really easy to work on yes. However as far as longevity and higher performance are concerned, the ls eats the old school stuff for lunch. A cam swap alone turns the ls motors into animals. There’s lots of people running 1000+ hp on mostly stock junkyard engines on forced induction. The hotrod article where they took the 5.3 that ended up being a 4.8 and put twins on it to the tune 1200 hp is an amazing read. In stock form I’ve seen them run past 300,000 when taken care of. If you want to do the swap as said before the best way to do it in my opinion is with a full donor truck or suv. I love the look of an old school small or big block in these trucks and they do perform quite well, they have for the last 60 years! I’ve had several of the old motors and I love them just as much as the ls but for different reasons. Op. It’s really up to you what you want to do, what you want to get out of your truck. If you want to get in and drive it and never have to tune it up except the occasional plugs, filters, belts and oil changes (not to mention cold weather start up) than the ls stuff is for you. If you don’t mind picking up a wrench to keep the old stuff in tip top shape and want to save a few dollars than a 350 is for you.
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne: 5” lift, 35’s, front dana 60 blah blah blah… http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB: 4” lift 33”s… in a million pieces http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 35x12.5x20’s Last edited by 57taskforce; 01-26-2019 at 03:34 PM. |
01-26-2019, 04:16 PM | #30 |
Cost, computer, lost vehicle value, complexaty, plus those engines are throw-a-way non rebuildable.............. Stay with stock imo. Far better..............
I BELIEVE IN JOHN 3:16 |
01-26-2019, 04:55 PM | #31 |
All about them K’s
I respect you and your opinion but this is false. Iron block ls motors can certainly be bored and rebuilt. Aluminum blocks can be bored, but not anymore than .010 usually.
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne: 5” lift, 35’s, front dana 60 blah blah blah… http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB: 4” lift 33”s… in a million pieces http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 35x12.5x20’s |
01-27-2019, 12:12 PM | #32 |
Junior Member
I'm going with a mix of the two, I'm sticking with the 350 but I'll be going SEFI and COP using almost entirely stock GM parts. eventually I'll be throwing a turbo on it sloppy style but for right now I just wanted to see how a motor from the early 70s is going to react to being modernized.
71 C/10 "Brooke" - The Rat Rod Tow Truck 98 Blazer "Hulky" - The Tow Rig - Sold 11 Regal - The DD 76 Kawasaki KZ900 - One Day I'll fix it 06 Street Bob - Soon to be Sold |
01-27-2019, 12:56 PM | #33 |
......can't help think about the difference in reality between 400hp on tap and 600-1000hp on tap.
Not that there isn't a clear difference, but highly unlikely that it is useful. A well built, strong small block (stroked 350 to 383) will easily produce 400hp and substantial torque and this will reflect on a light back end vehicle, like a truck, in a big way. However, in reality (...you guys all know that place)....show some pics where you are using and putting up that extra hp from these LS builds? Hopefully there are some smokin' 1/4 mile times out there....because this just can't be parking lot burn out stuff....you don't need much power to do that. Post up your pics from your power results....and no, I don't mean a paper dyno sheet that you keep in the glovebox, lol. If you some timing sheets showing your 1/8 mile or 1/4 mile times...those would be cool to see. Now if it is just the driveability and reliability element....very hard to beat an LS motor, even a stock one. All good Coley
....for some men, there is experience, skill and effort....for the others...there is visa and UPS LOL 1966 Chevy 1/2 ton (Florida- Red/white) 1972 Chevy 1/2 ton (California- Blue/white) 2005 Chevy Silverado HD2500/Duramax 2000 Dodge Ram 1500 |
01-27-2019, 01:01 PM | #34 |
the 327 (5.4) is nothing like the 323 (5.3)
01-27-2019, 01:02 PM | #35 |
At the body shop.
A LS swap will be high on my list with my 68 the 454 in it has something coming from together. When it expires. LS- 4l60 or 80e depending on the engine size.
01-27-2019, 01:45 PM | #36 |
Seems to me if you keep the original engine and trans, and don't have to cut up the chassis to put in the LS, then you're not losing value. You can always keep the engine around to include as part of the sale, if/when you decide to sell. If someone really wants a non-LS, they can always put it back.
1970 C10 LWB Stepside 1971 Dodge Dart 1993 Buick Roadmaster Estate Wagon |
01-27-2019, 02:19 PM | #37 |
On the value-loss question... Value loss swap: I've seen so many LS-swapped trucks that I turn away from immediately because...the junk yard motor was put in there without even being cleaned. The top cover is nasty, dirty and stained a decade+ of road grime and engine oil. The block is nasty, heads are nasty and all the outer components and wiring are also direct from the junk yard...dirty as hell and just grimy looking. The engine typically is running...OK... but not totally excellent like a new motor with all perfectly working sensors and perfect tolerances. The thing starts and idles...OK... but it's got 200+k miles on it so it's starting to get tired and will have all manner of sensor issues until they have all failed...eventually... Non loss LS swap: These typically are those cars and trucks that received either a spankin new GM crate LS or the owner/builder/installer actually took the time and expense to go through the salvage engine to check the bearings/seals/rings/valvetrain, cleaned the engine and tested/repaired/repla ced any failed components and dressed the thing up a bit to make it look like it's didn't just come out of a 2002 Sierra Van or whatever. Also, the ECU and wiring appear to have been well thought out and placed properly either in the engine bay or in the cabin of the vehicle. Thankfully it's usually easy to spot one of the Value-loss type LS swaps out there and even easier to walk away from it! -klb
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi 07 335 sport turbo 6sp 94 Trans Am GT LT1 6sp posi -- sold after 22yrs 99 540 sport V8 6sp -- sold 73 240z L24 4sp -- given to friend 68 C10 step 350/350 3.73 open -- sold |
01-28-2019, 08:13 PM | #38 |
Right but the same goes for any old SBC you see in a truck too. How many of those are spit shined and rattle canned with cardboard "shields" to keep the paint overspray away from other areas, butched wiring, so it seems like a silly argument against them as shadetree is shadetree no matter what is done.
If a dirty motor runs and is put into another vehicle and it still runs, who really cares though? That is what is done with a lot of SBCs. machine work and complete overhaul aren't cheap. "what cam is in that?" "oh its got a 3/4 cam camel humps and a race converter" with a 2.73 rear on a 327 with a 750 double pumper carb. If the work is done properly, most of the expense of the swap is the conversion. The motor is the lowest expense. Kool aid? Get real.
Running in place gets you nowhere fast. -me 1968 GTO 4-spd covnvertible 1970 K-20 4-speed, factory AC. |
01-28-2019, 11:32 PM | #39 |
Some, but not all...
I cleaned mine up a bit and did a “bit” of freshening up while I was at it ...but you are correct; you should se the before pictures! And it ran fine before but just a WHOLE lot better now |
01-28-2019, 11:52 PM | #40 |
All about them K’s
nice!
01-29-2019, 01:11 AM | #41 |
I've seen these posts , and asked myself also. I've bought 3 or 4 LS trucks for the drivetrain and still haven't. You need to determine what you want from your truck. My LS daily drivers are perfect at what they do , And my sbc 67 and sbc 68 are perfect at what they do. Heck, my 68 still has points...Ive been lucky at finding cheap good sbc's , and I just like the 50 year old technology still working. It's all what you want , not the money or the work
01-29-2019, 10:05 AM | #42 | |
I have nothing against Gen 1 small blocks. I have 2 running (with TPI). But the LS engines really are next level.
'83 K20-TPI '73 C10 '79 C10-ex-diesel(SOLD) '07 Tahoe(Son driving) '14 Suburban-DD '71 C10-current project |
01-29-2019, 10:31 AM | #43 |
The LS is like a bunch of absolute expert-level hot rodders got an unlimited budget and said "let's build the best pushrod V8 ever!"
We'll start with a deep skirt, 6 bolt main block. Raise the cam for stroke clearance and valvetrain stability. And add .020 of deck height over the SBC for good measure. Then use a gerotor oil pump on the crank snout. Much more efficient than a gear pump. "We need a large cam core" they said. 55mm and it allows for much higher lift and duration with nice stable ramps for low spring pressure and lower roller lifter speed. Brilliant! Low tension rings, 6.098 cracked cap rods , 3.62 steel crank, hypereutectic pistons outta the hole for quench. The cylinder heads first line on paper was injector targeting, as it sprays right on the back of the 15 degree intake valve. Then replicated, high velocity, high flow intake ports, pedestal mounted rockers (big gains there at rpm), and beehive springs. Composite, coolant isolated intake manifold with long runners for "area under the curve" torque production. The TBSS/NNBS is the factory apex for production manifolds. All precisely controlled by an ECU using just a handful of simple sensors. Also, stock engines are really choked down and restricted from their potential. The 5.3 in my 68 Nova has been 11.74@114 with just a cam, springs, headers, and underdrive pulley. Using a TH350 and 3.73 gear. That's yesteryears 383 type performance in a simple junkyard swap.
1970 C10 Turbo LM7 5.3/LS6 cam PT7675/4L80E/Holley Dominator EFI/E85 Moser 9" 3.25/4 wheel discs 11.16@121.07 Last edited by Heavymetl; 01-29-2019 at 12:48 PM. |
01-29-2019, 12:02 PM | #44 |
One thing that would really help the LS engine option....would be a kit to change the appearance under the hood.
It is a modern engine, and as such...is as boring as watching paint dry compared to the original engines. Plastic covers, etc, etc....serious yawners with the hood up. As a daily driver you never have the hood up so if that is the case...not an issue. However if you like going to show'n shines, etc and popping the hood....don't expect anyone to linger too long looking at the engine, at least any longer than they do at the Toyota dealership, lol. The folks at Holley understood this when they did their super nice '67 C10 shop truck....check out the detail on that newer engine. Very clever and very nicely done to disguise it as an original engine. All good Coley
01-29-2019, 01:45 PM | #45 |
why not a 5.7L?
1970 Chevy C-10 Stepside My build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=528167 |
01-29-2019, 05:56 PM | #46 |
Lots harder to find now as those were only put in the 4th gen camaros & FB plus corvette through 04 as opposed to millions of LM7 (5.3L) blocks.
Nice looking build Slowguy!
01-29-2019, 06:10 PM | #47 |
Post Whore
A 406 SBC can be done for around $3200-up w/ 425 horses & 525 foot pounds of torque. OR>>>>Find a 1973-76 El Dorado 500 cube motor (rear sump) & get maximum torque, simple tuning & 17+ MPG @55 MPH at 2000 RPM. Or follow the popular crowd w/the latest trends of giant wheels w/O-ring tires, LS & 'patina' that was contrived at best. http://www.superchevy.com/how-to/148...-block-torque/
01-29-2019, 06:45 PM | #48 | |
Workin to live...
Jason |
01-29-2019, 06:50 PM | #49 |
A nice 350 small block, stroked to 383 with a kit, a professionally built Quadrajet, a reasonable cam for a heavy vehicle (NOT long duration), new electronic ignition, a new/quality dual plane intake manifold and professional dual exhaust.....and your golden.
You will light up your tires at will, idle great, accelerate like hell, you can detail the heck out of it custom or leave it completely stock appearing. Ba-da-bing. All good Coley
01-29-2019, 07:43 PM | #50 |
Many guys who have gone the LS route toute mileage as the best advantage and really if you ask me that’s where the advantage ends,even then it’s marginal when you can buy a stand alone Efi and get in that range easy. Friend of a friend has a 383 making an easy 550hp with a 5 spd and a efi and he gets 20 plus mpg all day long. To each there own,personally I find the LS swap the world fad to be getting out of hand.
