02-06-2019, 01:20 PM | #26 | |
Re: Explain auxilary battery purpose to me
j
White K20 |
02-06-2019, 01:35 PM | #27 | |
j
White K20 |
02-07-2019, 08:00 AM | #28 |
the ford solenoid will not work(it will for a while...) as it is not designed as a continuous duty solenoid....the confusing part is that there are continuous duty solenoids that look just like a ford solenoid, so people replace them with ford solenoids and the fun begins....
1970 short step c10 leaf spring 454 |
02-07-2019, 09:56 AM | #29 |
Old member
jeffahart,
thanks, yes I have built many carts using these type contactors, and they get the job done. I have never had one to fail me yet in over 20 years of modifying carts. They are continuous contactors and you can buy them for any voltage you need. If you want it to be factory correct then you don't have much choice as to what you can use for the parts but if you want it to just work right and last for a long time. Then use the right kind of parts for the job. As far as those Ford solenoids go have you looked at their amp rating? The short of it is that it takes 8-10 amps to hold the solenoid in place while starting your motor the draw can spike to 30 amps while it is engaging the car starter. A winch will over load these as soon as it starts winding. 100 amps and higher if the winch has any kind of load on it. http://www.smittybiltdepot.com/aux_i...7.pdf&line=S/B
