#26 |
![]() ![]() Join Date: Mar 2016
Re: Flipper turns keeper... 67 upgrades
I posted the color code in my front end friday's thread.
'35 1/2 ton Pickup (bought 2020) '68 C10 Suburban (bought 2021) '72 K5 Blazer (bought 2013) '67 Stepside (bought 1997-sold 2021-partially bought back 2024) '96 Bronco Eddie Bauer (inherited 2010) My 1st day here-'67 C10(sold)and '72 K5 Blazer http://67-72chevytrucks.com/vboard/s...d.php?t=702056 "Another Blue Chevy"(1935) http://67-72chevytrucks.com/vboard/s...d.php?t=799203 ![]() ![]() Last edited by 3757chevy; 01-30-2019 at 12:35 AM. |
#27 |
Here are a few pictures of the compressor and lines installed. The ac will make Texas heat bearable.
![]() Slammed 53 5 window Blown/Bagged 54 Pickup Patinaed 67 LS stepside Supercharged 67 Nova Bagged 69 Suburban Turbo'ed 5.3 LS |
#28 |
Today we wired up the dual electric fans to the computer control line and added an AC override to turn them on as soon as the AC switch is activated.
Also finished adding the radiator top cover and relocated the wiper fluid container. Little things the seem to take awhile😁
#29 |
Check out the tire and rim combination for the spare. I have mounted up all new tires on some old worn steel wheels from one of my square body parts truck to fit the patinaed theme.
I know it is not for everyone but I really like the fact that it all looks old and worn when in fact it is in like new condition underneath. Any comments out there?
#30 |
Took a crappy picture in an uneven parking lot today to try and show the new lower stance. It looks higher in the rear than it really is because of the parking lot slope. When I bring it home in the next couple days I will get better ones.
I am still debating on air ride. I have it on 2 of my 6 rides and not sure if I will add it to the shop truck just yet. Kind of like the thought of just get in and go with no worries.
#31 |
So we finished the paint in all the rust repair areas and I am pleased with the outcomes. They turned out good and cleaned up the overall appearance of the truck.
#32 | |
'35 1/2 ton Pickup (bought 2020) '68 C10 Suburban (bought 2021) '72 K5 Blazer (bought 2013) '67 Stepside (bought 1997-sold 2021-partially bought back 2024) '96 Bronco Eddie Bauer (inherited 2010) My 1st day here-'67 C10(sold)and '72 K5 Blazer http://67-72chevytrucks.com/vboard/s...d.php?t=702056 "Another Blue Chevy"(1935) http://67-72chevytrucks.com/vboard/s...d.php?t=799203 ![]() ![]() |
#33 |
I really like the stock mirrors and the fact that I can now see along side of the truck. I had a couple of close calls without mirrors when I first got the truck.
I don’t know how people drive without them.
#34 | |
I have to change the wheels as I am going from 6 lug to 5 lug. I figured the if I wanted to change them up I can always paint them any color in the future. I guess I will drive it awhile and fight it out down the road. For some reason I just like the super weathered look.
#35 |
Installed the seat belts, seat, and carpet today as well.
I bought this seat from a guy in Dallas and haven’t decided if I like the cover. It might be cool to recover it but there is really nothing wrong with it structurally or mechanically. Also, the new carpet looks great in the truck but is making the top of the seat look kinda gray instead of light blue. After all the work the seat looks old in there now. Funny how I never noticed it when everything was dirty and dingy. Oh well, it’s only money
#36 |
Tomorrow I will finish up the inside of the doors, door gaskets, door panels, window tracks, and tint the side windows.
The stereo needs wired up, the compressor wiring will be completed, charge and test the AC system, and finish up a few loose ends. The power brakes are giving me fits. I put discs on it first and left the manual drum drum master cylinder on it. It stopped great and straight but took a lot of pedal pressure. While working on everything else I added the booster bracket, booster, and the new master cylinder the bled the entire system a couple of times and there is absolutely no air in the system. Now it stops ok but takes crazy amount of pedal pressure. Worse than without the booster. Acts like the booster isn’t working at all and I have a ton of vacuum at the booster. It still has the drum/drum proportioning valve on it. I had that on it when I did the disc conversion only and it stopped great. I don’t understand what could have gone wrong. Any help is appreciated.
#37 |
This is long shot but a friend of mine just installed a new aftermarket booster on his '79 CJ7 with same result you have. Turns out the new one way vacuum valve at the booster was bad not allowing any vacuum into the booster diaphragm. Tossed a valve from one of my old square body boosters and she works like a champ!
Steve weim55 Colorado |
#38 | |
I figured out the braking issue. I added a cup on the backside of the booster to seal the hole at the firewall. It was to tight and wouldn’t let in any air to the backside of the booster. I cut it out and now have great brakes!
#39 |
That reason is because it’s a great look. A genuine patina looks as good as a fine wine tastes. On the other hand a bad “faux-tina” looks as bad as warm flat schlitz malt liquor tastes. 🤮
Brian 1972 C10, "Loyd", LWB to SWB, 5.3, L83/6L80e, 4:11 Tru Trac, Air Ride, VA, DD, 20" Coys, 4 wheel disc, A quick LS swap turned into a 6 year frame off resto-mod. |
#40 | |
Here are a couple of mine to enjoy.
#41 |
So here it sits back in my drive way after we were doing all the paint and rust repair at my buddies shop.
The first pic is how she currently sits. Still have to change out the rear axles to get the rear tires and patinaed wheels on her. Will be nice when all the wheels match.
#42 |
Front end now and when I got her. What does everyone think?
![]() Slammed 53 5 window Blown/Bagged 54 Pickup Patinaed 67 LS stepside Supercharged 67 Nova Bagged 69 Suburban Turbo'ed 5.3 LS Last edited by HSRACER; 01-31-2019 at 11:57 PM. |
#43 |
Front fender picture before and after.
#44 |
Passenger rockers
#45 |
Inner roof repairs
#46 |
Computer relocation and power brakes added.
#47 |
Did you use the ceramic lizard skin only or the sound barrier stuff too? What was your steps? Epoxy primer, paint, lizard skin?
Thanks, and your build is coming along nicely! Tom .
TA_C10 Stage 1 build - http://67-72chevytrucks.com/vboard/s....php?p=8333444 "It's only money". ![]() |
#48 | |
I didn’t use the ceramic because I am putting carpet over the lizard skin. We primed the entire interior except the floor and painted every the blue color.
#49 |
So you can put the lizard skin on direct metal with no primer?
#50 |
We sanded and scuffed the original paint on the floors and kick panels before laying it on. We did prime the new metal that was welded in like the rockers and the lower kick panels.
I am not sure if I would put it over bare metal.
