Old 01-31-2019, 10:33 AM   #26
volksworld
Re: Looking at a C10 to buy near Long Island NY
oh yeah...as a p.s.....long island has some of the highest taxes, insurance rates and utility bills in the country and as a result shop labor rates are crazy so trying to find a shop to do any kind of resto work at an affordable price is virtually impossible
1970 short step c10 leaf spring 454
volksworld is offline   Reply With Quote
Old 01-31-2019, 11:51 AM   #27
72c20customcamper
72c20customcamper's Avatar
I left LI in the 70's. Nice place to live but had to go three NYC to get off. Now LI is so grounded it's terrible. I haven't been back there in 5 years.
Mark
1969 AMX ,
1968 c20 stepside ,85 K20
1977 Suburban sold
68 anniversary.
Old 01-31-2019, 03:24 PM   #28
cypressbog
Go Pack Go!
Don't ever buy a vehicle sight unseen...ever.
cypressbog is offline   Reply With Quote
Old 01-31-2019, 04:48 PM   #29
clay68c10
clay68c10's Avatar
I would add to Grumpys comment about I40 and say that you only look west of I35 also.
West TX, Az, New Mexico, southern Nevada, and Cali.
You can find good stuff in Colorado and Wyoming, but weather this time of year won’t help out your shipping situation.
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO
http://67-72chevytrucks.com/vboard/s...d.php?t=788602
93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday...
05 Jeep Wrangler Unlimited. 3” lift & 6-speed
02 E320 the insurance total “free car”
13 Tahoe LTZ
clay68c10 is offline   Reply With Quote
Old 01-31-2019, 05:26 PM   #30
godlytroop
Thank you everyone. You've shown me that it's best to look closer to home.
Followup question:
What is the general consensus on long bed to short bed conversions and/or auto to manual conversions? I want to end up with a short bed with a Muncie M20/M21/M22 in it. I'm thinking it may be best to find a short bed and do the manual swap after the fact since it's so hard to find already done.
I'd be doing all the work myself so I'm only worried about parts cost not labor.
godlytroop is offline   Reply With Quote
Old 01-31-2019, 07:02 PM   #31
volksworld
auto to stick conversions are basically a bolt -in...pedal setup, linkage and z-bar can probably be found here in the classifieds and shouldnt be too bad to ship...used muncies however seem to be close to a grand ....more for something thats been gone through...probably have to have a driveshaft shop make you something the right length and yoke (i believe an auto trans is longer than a 4 speed so shaft needs to be longer)...and new clutch ,pressure plate, throwout bearing...new or used flywheel and bellhousing/scattershield....all should be within normal capabilities....however shortbed conversions require another bed and driveshaft (the easy part) and the chassis itself to be properly cut, shortened and welded back together ....not exactly a newbie project unless you'd like to build a deathtrap....and the price of shortbeds is high enough that you have to be careful that you dont wind up buying one that someone that had no idea what they were doing shortened...bring along someone that knows what they're looking at to verify you're not buying something that was aborted together
Old 01-31-2019, 07:10 PM   #32
godlytroop
Thank you! Will do. I'm going to look at a shortbed this weekend then just planning to do that transmission swap. I've swapped the motor (and while doing that removed the transmission) in my Camaro so I'm pretty confident I'll be able to make it happen. Thanks for your input, I agree trying to do a shortbed conversion is probably out of my wheelhouse right now.
1967 Camaro Emerald Turquoise
RSSS 396, Muncie M21, 12 Bolt 3.73 Posi, Hotchkis/QA1 Suspension
1970 CST/10 Dark Olive
Short bed Fleetside, 350 SBC, Muncie M21, PS/PB
Old 02-02-2019, 09:47 PM   #33
derotoreut
Roto Reuter thats the name...
derotoreut's Avatar
After living in Buffalo all my life there aren't a whole lot of options for clean trucks. I went the other way and bought my 71 original SWB out of Phoenix. Before I did, I had someone go and look it over in detail. I would not buy a truck sight unseen. Plus I got a better price then I could have in this area. Take a look down south or out west.
~ Dan
My 70 K10 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=782232
My 71 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=651394
1970 SWB Fleet K10 4X4, 5.3L LM7, 4L60E, Dakota Digital RTX, Vintage Air, Ididit tilt
1971 SWB Fleet C10 - Original SWB Arizona truck, new custom restoration project
"Kick out your motor and drive while you're still alive - kick it out!" - Heart 1977
derotoreut is offline   Reply With Quote
Old 02-03-2019, 11:03 AM   #34
zicc1835
zicc1835's Avatar
i spent the first 59 years of my life on long island....it is an island...so salt water and salty humid air...parts of it go underwater in hurricanes and noreasters, and the roads get covered in rock salt and sand for the winter snows....the cab on my daily driver 70 literally fell off in about 1983....replaced with a cab from oklahoma cause it cost less to buy a rust free cab than to properly fix a rusty one....so either the truck you're looking at spent its entire life in a garage and was never driven in winter, or its had a hell of a lot of work (of unknown quality) done to it ....or maybe had a cab swap and the numbers dont match, pop rivited vin tag that your state may red flag upon inspection, etc....the rear view of the truck showing the funhouse mirror reflection on the bedside makes me think this thing is a bondo sculpture with a maaco paintjob...or acrylic enamel shot in the driveway
x2 I bought this 9 years ago factory BB Texas (basket case build thread)truck that ended up spending to much time on Long Island. granted I knew what I was buying 2k back then 5 years to get it finished nights and weekends lots of sheet metal repair . Grumpy is right although I would draw that line on your side of the Rockies north and south I have 2 more purchased pre Barret Jack run -up both from the low desert and I gladly pay my transporter fee for surface rustthe 67 towing it i bought in a u-pull yard in Newburg Oragon for 1k runnung drove it up on the trailer ...they are out there maybe not as reasonable anymore but plenty of them on your side good luck be patient
zicc1835 is offline   Reply With Quote
