02-08-2019, 05:51 PM | #26 |
Re: Grinding/Screech from Block
I saw the same thing,
1967 C10 Step side 1970 AMX 390 1977 Datsun 280Z highly modified with '95 LT1 power |
02-08-2019, 08:40 PM | #27 |
SOLVED - 5/16th plug in the hole mentioned.
Can anyone explain what that hole is for (I heard power braking?) and if these trucks use that?
1969 |
02-08-2019, 08:42 PM | #28 |
It's a vacuum port that can be used for a power brake booster. Trucks use it if they have power brakes (vacuum boost).
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson |
02-08-2019, 09:14 PM | #29 | |
1967 C10 Step side 1970 AMX 390 1977 Datsun 280Z highly modified with '95 LT1 power Last edited by ga-stepside; 02-08-2019 at 09:44 PM. |
02-08-2019, 09:22 PM | #30 |
Yep. Sounds like a massive vacuum leak
Plug that port on the back of the carb.
My build page http://67-72chevytrucks.com/vboard/s...d.php?t=764662 My cabinet building site http://www.cbcabinets.com |
02-08-2019, 10:15 PM | #31 | |
I'll check for that hose at first light tomorrow!
1969 |
02-09-2019, 12:02 AM | #32 | |
02-09-2019, 04:36 PM | #33 |
The hose coming off the forward portion of the brake booster is going into a plug that's attached to the top of the intake, and the other side of the plug is going to a hardline towards the back. I'm assuming it's just bypassing the carb.
1969 |
02-09-2019, 05:38 PM | #34 |
That should be fine, my AMX power booster come off the intake, its the same vacuum as the bottom of the carb. No clue what that hard line is for, possibly for the transmission.
02-09-2019, 05:47 PM | #35 |
Who Changed This?
If I am not mistaken, that hole is threaded for 1/4" tapered pipe. A 5/16" fitting may still allow a small leak. Spritz the fitting with carb cleaner, and if the idle changes, get a 1/4" tapered pipe plug. It should seal with no thread treatments, BTW.
02-10-2019, 10:03 PM | #36 |
yep, it should be a 1/4" tapered pipe plug that goes in there
