02-04-2019, 12:57 PM | #26 |
Re: 64-66 GMC Cab Big Window Part Out Power Brakes
Long shot request: Any chance you have a complete lock cylinder set off this truck (like the one pictured) ? Glove box a plus, but not critical. Thanks.
02-04-2019, 02:06 PM | #27 |
I can check but it is getting harder and harder to get a matched set . Usually over the years something has been changed out. I might be able to come up with a set like the one pictured but no key. Pretty sure you are aware that you could have a locksmith make a key and match the set. Thanks .
02-04-2019, 02:31 PM | #28 | |
02-04-2019, 03:01 PM | #29 |
Ok , mine are probably not much better. Nebraska farmers were kind of hard on stuff. Thanks
02-05-2019, 07:00 PM | #30 |
Have any other parts in Palomino Tan? Hood?
02-05-2019, 09:04 PM | #31 |
Sorry no hood . Just the cab as shown . Thanks
02-06-2019, 07:25 AM | #32 |
If you do end up cutting the cab, how's the area around the dimmer switch?
02-06-2019, 10:40 AM | #33 |
I can check on the dimmer area. About 10 degrees right now so probably will not cut for the next week or so. How big of area do you need ? Thanks
02-06-2019, 09:24 PM | #34 |
If it's a low hump cab I might be interested in part of the hump, mine has been modified.
02-06-2019, 11:31 PM | #35 |
No worries on time. Just whenever you can get to it brother. I would like to find a piece that's from the left side (under kick panel seam) and maybe 2-3 inches around the switch recess.
02-09-2019, 08:58 PM | #36 |
02-12-2019, 03:33 PM | #37 |
Matt , just to let you know that I received your payment on the outside trim. I included all the fasteners. Was shipped today via USPS Priority . Tracking sent in pm.
Thanks again. Paul |
02-12-2019, 03:35 PM | #38 |
02-12-2019, 03:47 PM | #39 | |
Thanks you very much, Matt
71 2wd k5 67 Nova |
02-12-2019, 09:02 PM | #40 | |
Thanks Joe |
02-12-2019, 10:43 PM | #41 | |
Thanks |
02-13-2019, 06:33 PM | #42 |
You do realize any locksmith can change a non-matched set into a matched set in about 30 minutes right? next to none of my 12 trucks had the matching locks and now they all do - easy as pie and cheap. Just manipulating the tumblers to match is all it is -
My Projects and Toys - All 100% Stock 1972 CST "Highlander" Blazer - 350 auto, PS, PB, A/C, Tilt, Tach, AM/FM & Positraction 1966 Chevy SWB Fleetside BBW Custom Cab, #'s matching 327 V8 & Powerglide, factory deluxe heat, PS, PB, Tinted Glass, sway bar 1961 Chevy SWB Fleetside BBW Custom Cab #'s matching 283 V8 & Powerglide w/ uber-rare Cool-Pack A/C, factory PB, deluxe heat, Clock 1961 GMC K1000 4x4 SWB w/ BBW, Custom Cab and numbers matching 305D V6 engine & 4 spd 1960 GMC SWB Fleetside BBW Custom Cab #'s matching 305A V6 & Hydramatic, factory PB, Clock, Tach, Compass, Hood Jet 1959 Chevy SWB Fleetside BBW Custom Cab w/ rare stainless bed trim, #'s matching 283 V8 & Hydramatic, Deluxe Heat, radio, spotlight 1958 Chevy Cameo #'s matching 283 V8 & Hydramatic, radio, window washers, Factory PB 1958 GMC BBW SWB Fleetside Custom Cab, #'s matching 336 V8 Hydramatic, Factory PS, PB, Clock, RSD, Deluxe Heat & Hood Jet 1957 GMC Suburban Pickup (GMC's Cameo) #'s matching 347 V8 Hydramatic, uber-rare vacuum ashtray, Factory PS, PB, Clock, RSD, Hood Jet 1956 Chevy 3800 1 ton w/ rare 9 ft stepside bed, factory 265 V8 w/ Hydramatic, factory PB, Custom Cab, deluxe heat, spotlight and hood jet. |
02-15-2019, 08:55 AM | #43 |
Paul, I received my trim parts yesterday, they look great. Thanks for such an outstanding job of packaging! Matt
71 2wd k5 67 Nova |
02-15-2019, 01:08 PM | #44 |
Thanks again Matt . I appreciate your business . Paul
02-19-2019, 04:05 PM | #45 |
How about the engine id tag on the drivers side kick panel area.
71 2wd k5 67 Nova |
02-20-2019, 12:38 PM | #46 |
Hi Matt .
Going to wait just a bit to see if the whole cab sells . If I get impatient , quits snowing and the weather warms up. I will probably start wacking. Thanks |
03-17-2019, 09:43 PM | #47 |
How is this area of the cab? And the front door pillers?
05-06-2019, 08:58 PM | #48 |
I want the interior sheet metal around rear window. Spot welded to window frame, door jams, then cut roof to leave me lip that’s attached to metal. Wanting to make my truck big rear window. Just shoot me a price !
07 Silverado Belltech 4-7 LS2 on stand 66 swb fleet in garage my build thread 76 stepside (painting for buddy)http://67-72chevytrucks.com/vboard/s...d.php?t=645332 |
05-06-2019, 09:08 PM | #49 |
400.00 for what you are talking. . Bare whole cab would be 500.00 if picked up. Shipping usually kills the deal. Any chance you can pickup in Nebraska.
