Old 02-11-2019, 11:05 AM   #1
MDPotter
MDPotter's Avatar
What master cylinder/proportioning valve to use?
I picked up a hydroboost from the junkyard this weekend. The junkyard didn't have any first gen Astro vans so I ended up with a unit off a 2008 Duramax. I'm converting from manual drum/drum to hydroboost with front discs, but what master cylinder and proportioning valve do I need? Can I reuse my stock master cylinder? I'm assuming the drum/drum proportioning valve isn't right for a disc/drum setup. I measured the bolt spacing on the hydroboost to my stock master cylinder and they appear to be the same.
This is in my 68 GMC C15 2WD.
Pics of my stock setup and the hydroboost:
1964 Chevy C10 - Gen IV 5.3 Restomod http://67-72chevytrucks.com/vboard/s...d.php?t=768632
1968 GMC C15 - Gen III 6.0 Restomod http://67-72chevytrucks.com/vboard/s...d.php?t=772047
1969 Chevy C10 - Restoration http://67-72chevytrucks.com/vboard/s...d.php?t=809184
1978 Chevy Scottsdale K20
1993 Chevy C1500 - 5.3/T56 swapped
2008 Silverado Duramax
MDPotter is offline   Reply With Quote
