02-18-2019, 09:05 PM | #26 |
SWB 4x4 Collector
Re: Lets Debate a Little.... LSX vs Duramax for swap....
There was a guy making emblems on Facebook.
TREVOR 1970 CST swb 4x4 (speedwarning,cruise,tilt,tach,8track, original red shoulder belts,tow hooks) 1972 Jimmy (soon to be Hickey cloned) 1971 Cheyenne Super 4x4 swb (tilt,tach,buckets, original blue shoulder belts,am/fm,cruise,tow hooks, dealer 8 track) 1972 Cheyenne Super K20 4x4 Custom Camper (tilt, tach, am/fm, tow hooks, bed toolbox, aux gas tank 1972 Cheyenne Super Crew Cab K30 4x4 Duramax, Allison, np205, buckets, tow hooks (CURRENT PROJECT) http://67-72chevytrucks.com/vboard/s...d.php?t=624819 1989 V3500 Crew Cab (454tbi, NV4500, np205) 1970 Chevelle SS (LS5 454,th400,8track,buckets,tach) :2004 Jeep Wrangler Rubicon (daily driver) WTB: 1968-70 Cruise Control Lever |
02-19-2019, 03:28 AM | #27 |
And my turn, 1st the intercooler I’m running is from a 2012 duramax van, if mine fits with a 70 grille the 72 should be even easier. The frame on our 157” chassis are 8” tall, sure is easy to put a lot of drivetrain under a truck with a tall frame and high hump. So that plan a duramax wouldn’t be too bad. On the flip side I just thought about when I mentioned rear shackle flips yesterday, what’s the true purpose, fun, pulling, both? If fun I say LS(with the shackle flip), pulling then duramax with your current suspension plans. Side note if diesel turned up combined with those long leaf springs I wouldn’t want a tall block due to axle wrap. Pulling with my 6.0 works just fine in my 5000 lb truck, pulling with my cummins in the 5500 lb truck works just as well but with less throttle. Just boils down to hotrod vs working truck. Lastly keep in mind my truck when it was a k20 with the cummins weighed only 5538 lbs so even a crew isn’t going to be anywhere near as heavy as a late model.
70 C10 highschool truck now C20 cummins powered 72 Crew Denali, Bigger, Stronger, Faster, well you get the point..... the ole 65 continental Syclone killer AWD T56 LS Paypal please pay as Goods&Services Madkidd00000007@yahoo.com |
02-19-2019, 07:15 PM | #28 | |
All about them K’s
Although I love the LS platform, escpecially that L99 in my Camaro, I used to have an l5p duramax and for a stock truck that’s the best performing engine I’ve ever driven. All of the duramxes have been very very good engines in my experience. I’ve driven the 5.9 and 6.7 Cummins and and all the powerchokes, but there’s just something magical about the Duramax. I like the Cummins as well but it’s still a step below the Duramax. If your gonna spend the time and money to build the crew do it right with that lb7.
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 315/75/16's ‘87 IROC-Z all original 50K mile survivor TPI 305 IROC Blue ‘10 Camaro 2SS/RS Aqua Blue Metallic #93 -version 2.0 Last edited by 57taskforce; 02-19-2019 at 07:32 PM. |
02-19-2019, 08:30 PM | #29 |
I drive a Ford 6.7 for work every day. It is a really powerful powerplant, especially with a tune. Unbelievable really. 10000 lb truck and it’ll outrun many cars. I completely agree with you on the lb7 though. That’s what my duramax is and there is something I just love about it. I think it’s one of my favorite trucks of all time. It’s just too bad the body can’t handle the salt. If I ever get a chance to get an lb7 donor for a really good price I’ll grab it up for sure. If I were doing a 4wd swap that would actually be my choice even though I previously said how it would be much less economical than an ls.
I do actually have a 7.3 ford sitting out back as well. That is one of the strongest engines I’ve ever seen. It has 500k on it and the engine purrs like the day it was new. The body rotted around the engine. If I ever get motivated for another project that can use that engine I’ll tear it all down and freshen it up. Just need a reason to. |
02-19-2019, 11:49 PM | #30 | |
02-20-2019, 02:10 AM | #31 | |
02-23-2019, 11:57 AM | #32 |
Sounds like the engines in question also serve different use cases. The Duramax obviously would be excellent with heavy loads. So, if it will be used like a truck it is a great option. But, is the rest of the truck capable towing of upwards of 15k lbs? If not, then that might just be wasted capability. And the LS motor a great engines, but probably don’t have low end grunt you may want in a truck. Of course, if this is just a toy that is all irrelevant. I like it like the Vortex 8100 (or 7400) option someone else mentioned. The donor would be be cheap to purchase and rebuild if needed. I’d probably pull all the factor EFI off of it and go with something like a Holley EFI Sniper and computer controlled distributor. You’d have the advantages of EFI but maintain a more period correct look.
