03-03-2019, 04:39 PM | #26 |
Re: 1972 4x4 Complete 350/350 Engine (locked up)
No problem they were rougher than I thought and dont want to send you anything you cant use or dont need. Thanks
1972 k10 Custom 10 Deluxe, short bed 4x4, 454, 4 speed (Sold) 1985 K30 Dump Truck 1986 Jeep CJ-7 1955 2 door 210 post |
03-03-2019, 11:15 PM | #27 |
I guess all the factory exhaust hangers have been swiped previously.. Thanks
03-03-2019, 11:23 PM | #28 | |
Behind driver and passenger cylinder head
03-03-2019, 11:40 PM | #29 |
More
Under 1-3 cylinder and under 2-4 cylinder bolted to block. These look to be factory ?? Also a heat shield bolted with the 2-4 side. So 4 plug wire brackets/bolts , 1 heat shield , the mystery water pump bracket/bolt... Anything else ? How about 20.00 shipped. For all? These plug wire brackets are pretty neat but id never take the time to route them I tinker on my engine too much... Haha
1972 k10 Custom 10 Deluxe, short bed 4x4, 454, 4 speed (Sold) 1985 K30 Dump Truck 1986 Jeep CJ-7 1955 2 door 210 post Last edited by hotsam; 03-03-2019 at 11:46 PM. |
03-04-2019, 12:49 AM | #30 |
I'll take it you have PayPal? Send me you PayPal will get you paid. Thanks. Cant think of nothing else at moment. But I'll sleep on it. Get you paid in a.m.
03-04-2019, 02:57 PM | #31 |
How about a front driveshaft?
03-04-2019, 10:33 PM | #32 |
[QUOTE=Eagle9502;8479557]How about a front driveshaft?
I do have 3 or 4 front driveshafts. A couple may be square body shafts but Im pretty sure all had 205 cases. I was told that the sm465 and 350 turbo setup uses the same rear shaft in our trucks. I would assume the front would be the same too ?? I will keep the original to my truck (3ott) shaft and one each for 350 turbo and sm465 (if not the same) but will be happy to pull measurements and see what I have. Thanks
03-09-2019, 09:27 AM | #33 |
Do you have the harmonic balancer to crank bolt? If so how much to ship to 44234?
03-09-2019, 09:38 AM | #34 |
I am thinking its gone by visual memory. But I will look in the morning and let you know. Im at work today. Thanks
03-14-2019, 08:35 AM | #35 |
I will take 400.00 for both diffs and , the 4 rough 15x10 wheels , and the stuck 350 engine picked up...
Ready to get this stuff moved on out of my way.
