Old 03-02-2019, 09:13 PM   #26
89AKurt
89AKurt's Avatar
Re: 307 torque build
Originally Posted by garyd1961 View Post
The 307 was a good motor. I thought the one in my truck was going to last forever but once they are worn out they aren't worth fooling with. A 350 with a set of vortec heads and a mild cam will give you more low end torque than you will ever squeeze out of that old 307.
I would run the 307 until it wouldn't go anymore and then buy a 350, no need to waste money on a 307.
I just found out that's in my truck. It runs like a champ now, so not touching it.
1968 Long Bed
2016 Honda Civic Coupe EX-T ticket magnet
89AKurt is offline   Reply With Quote
Old 03-02-2019, 10:38 PM   #27
garyd1961
As I said the 307 is a good motor, just not worth putting money into when you can get better performance out of a 350 for less money. As the old saying goes there is no replacement for displacement.
garyd1961 is offline   Reply With Quote
Old 03-05-2019, 05:53 PM   #28
Coalkracker
Thank you for all the info, i wasnt expecting this many answers! Maybe I will just keep it at stock specs and keep it running. I have a feeling the rings may be going bad as well so i may have to tale care of that but even with a cgeap rebuild kit i wont have much into it at all.
Coalkracker is offline   Reply With Quote
Old 03-05-2019, 09:35 PM   #29
6T7 C10
If you can do the labor yourself the right rebuild kit of chosen gaskets, valve seals, bearings, and cast iron rings along with attention to detail should do the trick inexpensively for many miles or engine hours on a chore truck. Check the cam for excessive wear as the early ones went flat on their own under normal use due to metallurgy. Good luck. We are cheering you on and please report back.
6T7 C10 is offline   Reply With Quote
Old 03-05-2019, 09:42 PM   #30
Coalkracker
I deff will. I have a lot of small things to work out to get it back on the road. Some im familiar with and some i am not so there will be a few questions along the way.
Old 05-24-2021, 04:22 PM   #31
54blackhornet
54blackhornet's Avatar
Over the last few weeks I upgraded to a GM HEI, boy what a big difference in power. Also had the original two barrel carb rebuilt. New plugs, wires and the little 307 runs like new. ...
71 C-20
07 Magnum RT AWD
54blackhornet is offline   Reply With Quote
