Old 08-05-2019, 03:55 PM   #26
MikeB
MikeB's Avatar
Thumbs up Re: Rag joint replacement with ujoint shaft, who’s done it?
Originally Posted by SCOTI View Post
I just finished swapping in a Jeep/Cherokee XJ u-joint shaft in place of my 2wd duallys rag-joint shaft. I purchased a new part for the swap from Summit Racing (Crown Automotive Steering Shafts; p/n 4713943) for $112 out the door.
Any mods required? Thanks for the tip!
Also, is the anti-vibration piece a rag joint? Any close up pictures? All of them on the Internet look like a silhouette and don't show much detail.
Mike
1969 C10 LWB -- owned for 36 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, recent AAW wiring harness, 5-lug conversion, 1985 spindles and brakes.
1982 C10 SWB -- converted from 250-six to roller cam 350, Vortec heads -- sold
1981 C10 Silverado LWB, 305, TH350C -- sold, but wish I still had it!
1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming.
Retired as a factory automation products salesman.
Worked part-time over the years for an engine builder and a classic car repair shop.
Member here for 24 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then!
MikeB is offline   Reply With Quote
Old 08-05-2019, 04:15 PM   #27
SCOTI
SCOTI's Avatar
I added my experience to this thread. I came in around the 2nd page (post #26).....
http://67-72chevytrucks.com/vboard/s...d.php?t=505196
The 'anti-vibration' part (of the column end of the joint) basically looks like the shaft is inserted into a rubber sleeve that goes between it & the u-joint:
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 08-05-2019, 04:48 PM   #28
MikeB
MikeB's Avatar
Scoti -- Nice write-up on the other thread! Sounds like a lot of mods to do it right.
After reading another post on that same thread (I think), I just ordered a $16 Borgeson rag joint kit. And if I don't like that, then I'll get their 000935 shaft with dual u-joints.
Can't say my rag joint is toast, but it doesn't take much for it to hit the travel limiter pins. The truck wanders just a bit with around 1 degree caster, which is all the alignment guy could get while keeping camber in specs. So I will start with the rag joint and move on as necessary.
Sure would like to have my box modified by AGR. Installed one a few years ago on a friend's 66 truck (with adapter bracket and Ididit coulumn). It made a huge difference -- quicker, but stiff on-center due to larger torsion bar. Almost like driving a new sports sedan!
Mike
Old 08-05-2019, 06:10 PM   #29
SCOTI
SCOTI's Avatar
It really wasn't that much effort.
Locating the donor was the first issue. After doing the used parts thing before, I skipped to the new/aftermarket search to compare costs first vs. a used unit. No brainer there once I found the Crown Automotive stuff. I provided the p/n so that should help the next guy & speed that up.
You have to heat the binding agent out to get the shaft assembly to the correct length. 3-4 mins w/a hand bottle Mapp torch & it was out. Reassembly can be done immediately but I don't like black oxide fasteners because they rust & I was having issues w/the SS replacements I sourced. It was the multiple trips to my local fastener spot (Elliot's Hardware) that slowed things as well as my unknown on whether the two halves even "needed" the binding-agent.
Time will tell in the long run but it's easily serviced now so I don't anticipate any problems if I feel the need to make any adjustment.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 08-05-2019, 09:36 PM   #30
Greenlee
Greenlee's Avatar
I just did mine yesterday. I bought a used Jeep XJ shaft off eBay. Wish I had known I could get a new one for only $112, but the used one seems fine! I didn’t take the shaft all the way apart. I just heated it up enough to get it to the length it needed to be. I collapsed it until it was about a half inch short and bolted in the top side to the column. Then I heated it again and pulled it out enough to attach to the steering box. I test drove it on the freeway and the steering definitely feels tighter.
My steering was pretty tight to begin with until a few weeks ago when my power steering pump went out. I think wrestling with trying to steer it without power steering must have killed the rag joint.
Greenlee is offline   Reply With Quote
Old 08-05-2019, 09:44 PM   #31
Greenlee
Greenlee's Avatar
After I got it all back together I noticed another problem. The lower bearing or bushing on the steering column just above where the steering shaft bolts up is wore out. You can wiggle the shaft back and forth. You can see what I’m talking about in this pic.
Old 08-05-2019, 09:57 PM   #32
Greenlee
Greenlee's Avatar
I just ordered the kit to repair the column. I had trouble finding it at first, but then found this one at Summit. It says it’s for a Jeep, but in the comments it says it fits a square body. Hopefully, I’ll have it in a few days and can get it put in over the weekend.
Old 08-06-2019, 11:11 AM   #33
drmatera
drmatera's Avatar
Thanks, filed for future reference
1981 K10 (4.8 / 4L60E swap)
1982 C10 (5.3 / 4L80E swap)
1985 C20 Suburban (454 / 4L80E)
drmatera is offline   Reply With Quote
Old 08-06-2019, 11:56 AM   #34
rgunlock
rgunlock's Avatar
I will be interested to know whether that column kit works for you Greenlee. I also had a lot of trouble finding the parts. As I recall, I ended up getting the bearing from a place that specialized in Cadillac parts and the rubber boot was supposed to be for a Jeep I believe. The bearing worked but the boot I got doesn't really fit right.
Rick
78 GMC K15 SWB, 350/NV4500/NP205/4.10s Project Hazel
71 GMC C25 350/TH400 - Project Angie
59 Chevy SWB Stepside (next in line? Not sure now )
2001 GMC Sierra K2500
rgunlock is offline   Reply With Quote
Old 08-10-2019, 06:13 PM   #35
Greenlee
Greenlee's Avatar
That part fit fine. Getting the old one off was a *****! I had to cut it in several places with a die grinder and peel it off.
Old 08-10-2019, 10:45 PM   #36
SCOTI
SCOTI's Avatar
Greenlee,
Did you have a lot of play or just notice it while in there working w/the shaft swap?
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 08-10-2019, 10:54 PM   #37
Greenlee
Greenlee's Avatar
Greenlee,
No. I just noticed it when I was doing the shaft swap. Getting rid of the rag joint got rid of most of the slop in the steering.
Old 08-11-2019, 03:08 AM   #38
SCOTI
SCOTI's Avatar
No. I just noticed it when I was doing the shaft swap. Getting rid of the rag joint got rid of most of the play in the steering.
Gotcha. Guess I'll double check & verify mine looks ok based on your situation.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 08-11-2019, 10:16 AM   #39
1774btcrew
1774btcrew's Avatar
I have used crown lower bearings quite a few times on columns that I have rebuilt. I have found that the bearing and plastic bushing fit great but most times I end up using the stock metal pieces off the GM columns as they seem to fit better.
AZPartsLocators on Instagram
1972 Cheyenne Super Short Bed big block "Blackie"
1977 Crew Cab GMC Short bed with 4BT Intercooled Cummins Diesel and a 4L80e "The Junkyard Dog"
1985 Crew Cab Chevy dually with 5.9 Cummins "The Big Dog" This is what my dad liked to be called by the grandkids before he passed so it seems fitting for his old truck.
1774btcrew is offline   Reply With Quote
