05-02-2019, 06:42 PM | #26 |
Re: 8 Track Mounting Brackets
Got mine today. Thanks!
05-05-2019, 11:51 AM | #27 |
I got mine yesterday. Thank you.
Question. One of them is angled. Is this the driver or passenger side bracket? Edit. Looks like passenger side based on the pics |
05-05-2019, 12:25 PM | #28 |
I will take a set.
72 Cheyenne Super 350 Holley EFI/700R4 67 Camaro SS/RS 68 Corvette 427 Tri-power 4-speed convertible 55 Chevy Belair Hardtop |
05-05-2019, 12:37 PM | #29 |
Both brackets are angled to match the angle of the player. When installed properly the brackets will line up and fit flat to the dash surface. It will be obvious which way they go. If installed on the wrong side they will be out about 16 degrees combined from the flat front face of the player.
You may find you have to install the brackets on the player, line up the one bracket closest to the passenger side of the vehicle with the left screw under the heater control. Then mark the location of the hole for the bracket closest to the steering wheel with a felt tip marker. Set the player aside, center punch and drill this hole. Remove the bracket closest to the steering wheel from the player and mount it to the dash hole you just drilled with a screw. Then install the player on this bracket using the holes in the player body. Then install bracket on the other side to the screw under the heater control with the same screw you took out of the heater control. Finally line up the long bracket to the heater diffuser screw. See the photos I provided in the other posts and let me know how it works out. |
05-05-2019, 12:39 PM | #30 |
Bcnya - I have more being made up. You are inline and will get you a shipping price.
05-07-2019, 07:18 PM | #31 |
Six more sets of brackets available.
05-08-2019, 09:54 AM | #32 |
Good morning....I sent you my shipping address. Thanks
05-15-2019, 03:39 PM | #33 |
Active Member
I'll take a set
Please PM me the total with shipping Steve 33914, Florida |
05-15-2019, 04:07 PM | #34 |
I'll take a second set.
Dan |
05-15-2019, 08:38 PM | #35 |
Dantip and burb71 check your PM inboxes.
05-15-2019, 09:55 PM | #36 |
Got mine today......thank you
05-16-2019, 05:40 AM | #37 |
Received my brackets and they look very well made. Thx!
05-16-2019, 09:54 AM | #38 |
I hope everyone on the whole board ends up reading this. I ordered a set of these Brackets from Don having no idea what it would take to actually mount the player beyond attaching them to it; I want all of you to know that these brackets arrived and proved to be 100% dead on correct in design and fit like a glove. Don has also painstakingly photographed and was able to describe to me what parts had to be modified on the trucks accelerator pedal arm and throttle cable - I was able through a series of emails and studying his photos to see what he did and achieve the same mods with relative ease. Now my player is installed. I made some mods to what Don did based on materials I had readily available in my toolbox so I am happy to walk anyone through what is needed while its all fresh on my mind. Anyone possessing a set of these brackets who is now ready to attempt install can call / text me at 256 486 1988 and I will walk you through all of it - here's a few shots of mine post install and a couple shots Don had shared with me on bending the pedal arm etc. I'll explain when we talk
My Projects and Toys - All 100% Stock 1972 CST "Highlander" Blazer - 350 auto, PS, PB, A/C, Tilt, Tach, AM/FM & Positraction 1966 Chevy SWB Fleetside BBW Custom Cab, #'s matching 327 V8 & Powerglide, factory deluxe heat, PS, PB, Tinted Glass, sway bar 1961 Chevy SWB Fleetside BBW Custom Cab #'s matching 283 V8 & Powerglide w/ uber-rare Cool-Pack A/C, factory PB, deluxe heat, Clock 1961 GMC K1000 4x4 SWB w/ BBW, Custom Cab and numbers matching 305D V6 engine & 4 spd 1960 GMC SWB Fleetside BBW Custom Cab #'s matching 305A V6 & Hydramatic, factory PB, Clock, Tach, Compass, Hood Jet 1959 Chevy SWB Fleetside BBW Custom Cab w/ rare stainless bed trim, #'s matching 283 V8 & Hydramatic, Deluxe Heat, radio, spotlight 1958 Chevy Cameo #'s matching 283 V8 & Hydramatic, radio, window washers, Factory PB 1958 GMC BBW SWB Fleetside Custom Cab, #'s matching 336 V8 Hydramatic, Factory PS, PB, Clock, RSD, Deluxe Heat & Hood Jet 1957 GMC Suburban Pickup (GMC's Cameo) #'s matching 347 V8 Hydramatic, uber-rare vacuum ashtray, Factory PS, PB, Clock, RSD, Hood Jet 1956 Chevy 3800 1 ton w/ rare 9 ft stepside bed, factory 265 V8 w/ Hydramatic, factory PB, Custom Cab, deluxe heat, spotlight and hood jet. |
05-16-2019, 09:57 AM | #39 |
something happened to my pictures so attaching here
05-16-2019, 03:16 PM | #40 |
Dantip your second set of brackets ordered are on the way.
05-30-2019, 11:59 AM | #41 |
Active Member
05-30-2019, 01:16 PM | #42 |
Burb 71 I replied to you with a pm message on May 15 and again on May 20.
Shipping with tracking to your location is $19.72. Paypal $94.72 to dkurjata@northwestcrane.com and I will get them shipped right away. Indicate you are paying for goods or services. I will pay the fees. Thanks! |
05-31-2019, 06:53 AM | #43 |
Active Member
Payment sent |
02-12-2020, 11:50 PM | #44 |
Saskred I replied to your pm this evening.
02-15-2020, 06:32 PM | #45 |
Saskred your brackets were delivered to your brother.
02-17-2020, 01:27 PM | #46 |
I will take a set pm address I send cash ken
06-08-2021, 11:21 PM | #47 |
I know this is an old post but do you by chance still have a set available? I would like a set .
06-09-2021, 10:28 AM | #48 |
I am pretty sure that I still have sets available.
Send me your address and I will get a shipped price for you. |
06-09-2021, 11:04 AM | #49 |
What's total shipping and fees to 30518 thanks pm me your pay pal if you still have a set
06-09-2021, 11:15 AM | #50 |
I will have to get this for you tomorrow if that is OK?
