05-09-2019, 11:18 PM | #26 |
Re: Something's wrong with this brake part.
The Leafs, Hubs, Backing Plates, and Diff Cover were stripped and painted with Rustoleum primer and gloss black. The axle housing was wire brushed stripped and then hand brushed with Por15 Gloss Black. The frame is also done with Por15. The Por15 lays down flat. There are no brush marks.
05-10-2019, 02:17 AM | #27 |
Location: 3,018 feet above the SoCal/Mojave Desert region.
Thanks. Doing my best to keep it alive. Those are great looking pictures. Your project is coming along great. And the information is giving me some good ideas. How did you go about lowering the front end??
05-10-2019, 04:03 PM | #28 |
Front has 2.5 in. Drop Spindles with 3 in. Drop Springs and shorter Shocks. While I was there, new upper and lower control arms, tie rod ends, adjusters and brake hoses were installed. Also an upper shock mount stiffener. My '72 came with a factory front sway bar, so new lowered sway bar mounts went in aswell. I understand that the Drop Spindles are not available right now because of re-tooling, you'll have to check availability.
05-10-2019, 06:50 PM | #29 | |
05-10-2019, 08:23 PM | #30 | |
05-11-2019, 01:01 PM | #31 | |
05-11-2019, 06:35 PM | #32 | |
05-12-2019, 10:29 PM | #33 | |
05-12-2019, 10:56 PM | #34 | |
05-12-2019, 11:11 PM | #35 | |
05-12-2019, 11:49 PM | #36 | |
05-13-2019, 01:39 AM | #37 | |
