Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Paint & Bodywork > Detailing
Old 05-06-2019, 09:29 PM   #26
oldman3
oldman3's Avatar
Re: 52 pickup door panel (interior)
Pic 1 I've already stapled material at bottom of pleats, glue two pieces of lauan together and stapled.
Pic 2 Now spray glue on bottom section and material.
Forget to show smoothing material over wood.
Pic 3 This show bottom section, material folded over, stapled and excess material removed.
oldman3 is offline   Reply With Quote
Old 05-06-2019, 09:38 PM   #27
oldman3
oldman3's Avatar
Forgot to mention, to sand the arm rest, to remove shine from fiberglass, so glue will stick to arm rest.
Pic 1 Arm and material sprayed with glue, now roll material up onto the arm rest.
Pic 2 Here's back side, glue on arm rest and material, ready to come together as before.
Pic 3 This show the excess material that needs to be pulled. I'm working out the wrinkles. It's hard to get them all out with this material, because of how thick it is. A different vinyl would maybe easier.
Pic 4 Not a good pic, but you get the ideal of how it looks, after pulling and pulling material. Sometimes you can't get out all the wrinkles, just do the best you can. If you don't think you want to try, you could always paint them.
Pic 5 Finished driver panel.
Old 05-06-2019, 09:41 PM   #28
oldman3
oldman3's Avatar
Hope this may help someone that want's a easy panel to build for their ride. Any questions, I will try to answer.
Old 05-06-2019, 09:45 PM   #29
oldman3
oldman3's Avatar
For those that find this thread, I should also mention that I did another style of door panels, back about 4 yrs ago. It has alot more detail on that panel. Here is the link http://67-72chevytrucks.com/vboard/s...d.php?t=662380 ...Jim
Old 05-07-2019, 08:14 AM   #30
8man
Jim, that is great work. Thank you for sharing.
8man-aka Robert
1948 on a S10 Frame, small block with a carb
1954 Cab, 53 Front and Bed, 50 Doors, S10 Frame, Power TBD
Build thread: "]http://67-72chevytrucks.com/vboard/showthread.php?t=746899&highlight=wife%27s+48[/URL]
[/URL]http://67-72chevytrucks.com/vboard/showthread.php?t=840204
8man is offline   Reply With Quote
Old 05-07-2019, 09:09 AM   #31
oldman3
oldman3's Avatar
Robert, Thank you. I don't do interior work very much, so I thought it might help someone. Thanks again for checking in out...Jim
Old 05-07-2019, 10:54 AM   #32
Rickysnickers
Rickysnickers's Avatar
That's a really great write up! Thank you. A couple of questions, how are you going to attach the panel to the door? And, if you have the door release lever and a window crank, i.e. a TF truck, do you cut those hole before or after the material is laid down?
Old 05-07-2019, 04:47 PM   #33
oldman3
oldman3's Avatar
First thank you. The owner of the truck wanted to use screws with black caps to hold the panel in place. Not how I wanted to do it, but he's the boss. Said he wanted to take it off himself if needed.
I would cut the holes first to fit everything and make sure they work. You could always make the hole larger for clearance, but a small cut in material would allow the crank to come thru...Jim
Old 05-08-2019, 01:10 AM   #34
doowoppwer
Beautiful work Jim. I double checked and I don't think you mentioned the spacing for the slats.
Roger
doowoppwer is offline   Reply With Quote
Old 05-08-2019, 09:13 AM   #35
oldman3
oldman3's Avatar
Roger
Thanks Roger. Most of the time I use 1/4" for spacing, this allows material on both sides of the slat and looks good. Thanks for checking out the thread...Jim
Old 05-08-2019, 10:19 AM   #36
blazer2007
do you think the 3-m glue you used would work for a headliner repair on a 78 chev truck. Can,t buy the proper landeau contact cement here in Canada
blazer2007 is offline   Reply With Quote
Old 05-08-2019, 10:40 AM   #37
MP&C
MP&C's Avatar
Beautiful work Jim!
Robert
MP&C is offline   Reply With Quote
Old 05-08-2019, 11:22 PM   #38
oldman3
oldman3's Avatar
Yes it should work, just make sure you put it on both parts, let is set up at least 5 minutes, lightly place it were you want, then start smoothing it out, once it's goes together under pressure, its impossible to get apart...Jim
Old 05-08-2019, 11:23 PM   #39
oldman3
oldman3's Avatar
Originally Posted by MP&C View Post
Beautiful work Jim!
Thanks Robert, just trying to keep up with you...Jim
Old 05-09-2019, 09:07 AM   #40
blazer2007
thanks, I like doing my own upholstery too and got some good ideas from your article
Old 05-09-2019, 09:43 AM   #41
oldman3
oldman3's Avatar
Glad you like it, that's the reason for the thread...Jim
Old 05-10-2019, 02:23 PM   #42
Rickysnickers
Ok, thank you for that. So, then I'm curious as to how you would hang them on your truck, if you don't mind sharing.
rick
Old 05-10-2019, 11:51 PM   #43
oldman3
oldman3's Avatar
rick
Rick, don't mind at all. This is a door panel I did 4 yrs ago, it's the way I do most of my door panels. This is the link http://67-72chevytrucks.com/vboard/s...d.php?t=662380 go to post 19 and 20, it shows how I do them. If more questions just ask away...Jim
Old 05-11-2019, 11:00 AM   #44
Rickysnickers
Wow, that is awesome. You are making me want to try and do that for my truck. Also, I did not know Reaper was your son. No wonder he has as much talent as he does. He's fortunate to have a dad to have shown/exposed his to this kind of stuff. I wish I would have had that. Thank you for your time!
rick
Old 05-11-2019, 01:18 PM   #45
oldman3
oldman3's Avatar
rick
Rick, thank you for the high praise. That's what this forum is all about, to help and encourage other to try new things. Mark (reaper) talents came thru him, I just gave him the basics, and helped guide. Cars, trucks have been a big part of my life, since I was 13 yrs old, he was around it all his life, never tried to force him in that direction, he just wanted to learn.
Any help I can offer on anything, just ask...Jim
Old 05-11-2019, 03:26 PM   #46
8man
Jim, I asked Mark to post a picture of the fender rack you built when he gets time. You wouldn't still have the plans laying around would you? Building one out of wood would pretty easy, and it looks pretty sturdy.
8man-aka Robert
Old 05-12-2019, 11:35 PM   #47
oldman3
oldman3's Avatar
Robert, never had any plans, just built them to the fenders. I will get some pics together with measurements and post them up. Give me a few days...Jim
Old 05-15-2019, 01:37 PM   #48
RockinKees
RockinKees's Avatar
It looks great Jim!
Never thought it could be so “easy”, Maybe I have to steal your idea in the future...
Cheers!! Kees.
1959 Chevy Fleetside Longbed
My build: http://67-72chevytrucks.com/vboard/s...d.php?t=643426
Kool Guyz CC
Instagram: _King_Kustom_
RockinKees is offline   Reply With Quote
Old 05-15-2019, 07:24 PM   #49
oldman3
oldman3's Avatar
Originally Posted by RockinKees View Post
It looks great Jim!
Go right ahead, that's the reason for me doing it...Jim
Old 05-16-2019, 09:15 PM   #50
oldman3
oldman3's Avatar
Robert (8man), sorry it took so long, but here's some pics and measurements you asked about, hope it helps, any questions, just ask. http://67-72chevytrucks.com/vboard/s...d.php?t=786978 ..Jimm
