Old 05-18-2019, 04:46 PM   #26
nlped
nlped's Avatar
Re: 1987 R10...aka Belushi
Worked on the interior today. Went ahead and pulled the seat (I have a USA1 oe style seat cover going back on it), the cracked up dash, and carpet out. Then did some spring cleaning on all the normally covered up bits. Also pulled the whipped stock speakers and the jankey single din radio out (it didn’t work anyway) and ordered a new Pioneer headunit (with Bluetooth) and speakers, so I can have some sounds. I’m super pleased with how clean everything is looking in all the nook and crannies...no rust at all!
Here’s a few before pictures...won’t get any afters until after the stereo stuff arrives though.
Carter
1968 Chevy SWB Fleet... Walt
1963-1/2 Ford Falcon Futura...Martha
nlped is offline   Reply With Quote
Old 05-18-2019, 04:46 PM   #27
nlped
nlped's Avatar
And, just to prove I’ve made some headway...
Carter
Old 05-18-2019, 06:03 PM   #28
TKCR
TKCR's Avatar
USA1 Industries has very nice seat covers. One of their older guys, that makes covers for the, he makes my covers for my seat restorations.
Old 05-18-2019, 08:47 PM   #29
nlped
nlped's Avatar
That’s good to know! Wish I had an in on a cover, but it’s all good. I’m not very hip on putting seat covers on, but I watched a few videos and it looks pretty straight forward. I’m going to work on getting it covered and cleaning all the plastic panels up while I wait on the dash speakers. I had one broken spring under the seat, but ‘modified’ it to put back into duty.
Carter
Old 05-18-2019, 10:29 PM   #30
TKCR
TKCR's Avatar
All your springs should be snug. If they aren’t, and they are floppy, then the grid needs tightened up.
Check your foam too. On the bottom, on each end, usually it needs glued back together. The foam splits apart. A foam spray glue will adhere the foam back together.
Old 05-18-2019, 10:49 PM   #31
nlped
nlped's Avatar
^^^ I’ll give it a closer look tomorrow. Thanks for the insight.
Carter
Old 05-19-2019, 12:00 AM   #32
cochino12
It followed me home?
cochino12's Avatar
Are you doing the dash also?
Adam
That's why they call it a shortcut Kyle, if it was easy it would just be the way.
86 c-10 SWB
85 CCSB
90 GMC K30 Crew SRW
1985 C30 Dually
cochino12 is offline   Reply With Quote
Old 05-19-2019, 08:24 AM   #33
nlped
nlped's Avatar
Yes I am. If you look back at post #22, you’ll see I got a new dashboard from Cheyenne Truck Parts...it’s a nice piece. As soon as I get the new dash speakers, I’ll put the dash in.
Carter
Old 05-19-2019, 10:32 PM   #34
nlped
nlped's Avatar
Hey TKCR, I did have a chance to have a closer look at my seat foam and it seams (pun intended) to be in good working order. It just had the one spring in the middle of the d/s seating area. After fixing that, the seat “sits” really well...the little bit of sag is gone.
I didn’t have any extra time to work on the truck today as I had a buddy ask me to assemble a 351W, as he’s in a time crunch, so I spent all day doing that. I’m going to take it to another buddy who has an engine dyno tomorrow after work to get some #’s for him. Should be in the low to mid 400’s.
Carter
Old 05-19-2019, 10:48 PM   #35
TKCR
TKCR's Avatar
Old 05-20-2019, 09:16 PM   #36
nlped
nlped's Avatar
Turns out the seat cover had a small tear, so I’m now waiting on a replacement. They were fantastic about it. I also went ahead and ordered new carpet and lower door panel pieces. That’ll finalize the interior.
Carter
Old 05-20-2019, 09:59 PM   #37
TKCR
TKCR's Avatar
They are having to send me a replacement too. Just got an order delivered Saturday. One of the covers had this. Looks like an iron burn.
Old 05-20-2019, 10:11 PM   #38
nlped
nlped's Avatar
Gahhh, that’s bad! Mine was at a seam...guess I should’ve kept my pun to myself
Carter
Old 05-21-2019, 08:19 PM   #39
nlped
nlped's Avatar
The carpet and related pieces showed up today and the color is MUCH better than the current carpet... Winner
The new Pioneer headunit and dash speakers showed up today too, but I didn’t get far, as I stabbed myself with a pick tool through the thumb and quit for the night. D@mn that was alotta blood from that little hole...almost completely through my thumb
And, the battery on the riding mower crapped out too. Shi77y night! I need a :beer:
Carter
Old 05-21-2019, 09:07 PM   #40
TKCR
TKCR's Avatar
Well it was good your parts arrived. But that sucks, stabbing yourself. I hope you didn’t bleed on your new parts, that really would have been BAD!
Old 05-21-2019, 09:17 PM   #41
nlped
nlped's Avatar
Yes sir and you’re correct, the stabbin’ sucked. But I had enough foresight to keep the blood under control‘ish.
Carter
Old 05-23-2019, 08:04 PM   #42
nlped
nlped's Avatar
Got home this evening and had a little bit of time to tinker. I got the front dash speakers mounted and did a quick test fit of the new dash. I gotta say, Cheyenne gets an A+ for fitment!!! It looks like it came in there! Now, I haven’t finalized the install of it because I want to do some additional cleaning up under the dash and some areas are more accessible from up top, so these pictures are of it just sitting in place. No weird bows, sticking out areas or misaligned areas even this way.
Carter
Old 05-25-2019, 07:57 AM   #43
nlped
nlped's Avatar
After pulling the dash one more time for some additional access behind the dash for radio wiring it’s now back in for good. I also got the new ACC carpet installed and it looks fantastic. I’ll get the rest of the interior panels in this morning and then I’m just waiting on the seat cover. But I really want to replace that stock steering wheel...may have to add it to the list.
Carter
Old 05-25-2019, 10:43 AM   #44
nlped
nlped's Avatar
I got a steering wheel ordered this morning after getting the yard work done (before it gets any hotter out).
Carter
Old 05-25-2019, 04:51 PM   #45
mongocanfly
Post Whore
mongocanfly's Avatar
Carter..trucks looking real good..nice interior parts...I recovered my seat...it was alot easier than I expected..your.(beatup) dash looked 100times better than mine did...which is odd..my truck lived nearly its whole life indoors...I cheaped out and used a coverlay dash cover on mine..
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 05-25-2019, 10:14 PM   #46
nlped
nlped's Avatar
Thanks Greg! The original dash pad was pretty hammered in real life between the cracks and the waves. That’s why I just bought this full replacement. Cheyenne had a great reputation and I see why after seeing this piece. The ACC carpet fit like a champ too. I’m going to finish cleaning the interior panels, pull the door panels to clean them & install the new door carpet panels. Then I’ll be waiting on the seat cover...
Carter
Old 05-25-2019, 10:43 PM   #47
TKCR
TKCR's Avatar
I like that Steering Wheel, looks really nice!! Interior is coming together nicely.
Old 05-26-2019, 09:15 AM   #48
cochino12
cochino12's Avatar
Interior looks great, you sold me on a cheyenne pick up parts dash! Haha. Think I'll order a couple on Tuesday
Adam
86 c-10 SWB
85 CCSB
90 GMC K30 Crew SRW
1985 C30 Dually
Old 05-26-2019, 10:23 AM   #49
nlped
nlped's Avatar
Thanks man! I am pretty pleased with the way it is coming along.
I can’t say anything bad about the dash. I tried one of the OER urethane (or whatever they are) ones on another truck and just wasn’t ever pleased with it.
Carter
Old 05-26-2019, 10:39 AM   #50
TKCR
TKCR's Avatar
Those urethane dashes will warp. There are only 2 places that I know that have metal frame dashes, Cheyenne & USA1 Industries. I have heard good things about both dashes.
I saw a guys URETHANE dash that was less than a year old. It looked like sh!t, it was warped/wavy. It was nasty looking
