#26 |
![]() Join Date: Feb 2018
Re: Started my bed wood.
#27 |
Who Changed This?
![]() Join Date: Jan 2013
When I pulled the plywood off my truck bed floor to replace it, the bed wood underneath was painted Hugger Orange. It's the original wood, I believe, because that plywood was laid down in '73 when my FiL had the camper shell installed. Just a data point.
#28 |
Believe 68 and up the wood was painted body color. There was some saddle paint on the wood under the bed strips
#29 |
This is what happens when you put your nuts and bolts in phosphorus acid.
#30 |
Got it in epoxy primer. Debating on if I should take out the few small dents in the bedside. But that would entail doing the outside of the bed since it's a stepside its single wall.
Let this sit a few days then on to high build primer and some polyester glaze coats on the bodywork.
#31 |
Tested some stain effects on the oak. Coated with BLO. I will use an exterior oil for the bed wood. The saddle paint was mixed with acetone . The iron oxide I made with white vinegar and steel wool. Not sure as of yet but I am leaning towards the ebony stain. I like the saddle but it's got a metallic look since theres metallic in the color
#32 |
I WOOD go with the ebony. what is saddle paint? leather stain or a local term for creosote?
#33 |
Saddle fawn is the trucks color code 525. I bought a quart to do the bed sides. I just added a tiny amount of the color to acetone
#34 |
![]() Join Date: Oct 2009
Have you considered full strength saddle? Would look factory
#35 |
Yes I did at first. But I could have used any kind of wood then even #3 pine knots and all .
Yes it would look like it was when it was new but I can't cover up beautiful wood with solid color. Would be Like having a Victoria secret's model in a snow suit.
#36 | |
Don't think you have white oak. White oak is used extensively in outdoor furniture. It is highly resistant to moisture so it shouldn't cup. You may have pin oak not good for exterior exposure. Red is not good for moisture either. Could be your wood wasn't kiln dried? Linky https://www.wagnermeters.com/moistur...white-red-oak/
#37 |
It just gets deeper and deeper. Doing the passenger bed side today. Had a few dents thought no big deal..... Well now I got the fender off because the bedside was bellied out. Smack it back and the dreaded oil drum sound . Had to heat shrink it before I could do any bodywork. Had to do it in front too. Something big and heavy must have slid into the passenger siderail .No dents in the rolls that strengthen the panel
#38 |
![]() Join Date: Mar 2018
Just did my bed with white oak and painted it with POR-15 and top coated with black paint. I was going to go with a dark linseed oil on the top (even bought it)....but started painting and just kept going. Not sure why but did??? I vote for the Iron Oxide
![]() [ATTACH]
1969 C-10 LWB SS 1969 Camaro Pro Tour 2002 Camaro SS LE Rag Top #937 |
#39 |
painted the bed yesterday.
