Old 05-24-2019, 10:14 PM   #26
cashforclunkers
cashforclunkers's Avatar
Re: Bunch of Parts
Originally Posted by anew4961 View Post
tail light housings to 27217 also
$20 shipped for all five sir. Thanks
Everyone that has sent payment I have your parts loaded up and will be shipping out Tuesday.
Joel
71' K10 stepside build
70'/04' GMC Crew cab project build
Bunch of parts for sale
Burb parts for sale
cashforclunkers is offline   Reply With Quote
Old 05-24-2019, 10:30 PM   #27
anew4961
Re: Bunch of Parts
i will take them
anew4961 is offline   Reply With Quote
Old 05-24-2019, 10:38 PM   #28
anew4961
Re: Bunch of Parts
how much on tail light housings shipped to 27217 thanks
payment sent
Old 05-24-2019, 10:39 PM   #29
anew4961
Re: Bunch of Parts
payment sent
Old 05-24-2019, 10:46 PM   #30
anew4961
Re: Bunch of Parts
Engine side harness. Pretty hacked up. Firewall plug is good.
-lt blue horn button and hardware. Plastic isolator not included! (afterthought I need that)
-four fleetside backup lt housings. two good w wire, two not so good.
-harrison heater core. has some green fuzz on it. not tested.
-71-72 turn signals and lenses not cracked
$25 each shipped
payment sent for back up lamps also
Old 05-24-2019, 11:08 PM   #31
Curtb1971
Curtb1971's Avatar
Re: Bunch of Parts
I'll take the 71/72 park lenses and housings. Thanks, Curt
1971 LSX "Bonnie" build thread
http://67-72chevytrucks.com/vboard/s....php?p=8026381
paypal is curtbarton1971@yahoo.com
Curtb1971 is offline   Reply With Quote
Old 05-25-2019, 08:24 AM   #32
Madkidd007
Madkidd007's Avatar
Re: Bunch of Parts
I’ll take the two good tailgate linkage/latch/supports
Pm your Paypal and I’ll get you paid today
Sounds good!
engine lift point and spark plug brackets
five truck tailight housings
two and a half tailgate linkages
pair of ratty armrests
v8 points distributor/cap
$20 ea shipped
70 C10 highschool truck now C20 cummins powered
72 Crew Denali, Bigger, Stronger, Faster, well you get the point.....
the ole 65 continental
Syclone killer AWD T56 LS
Paypal please pay as Goods&Services Madkidd00000007@yahoo.com
Madkidd007 is offline   Reply With Quote
Old 05-25-2019, 08:55 AM   #33
Chevy Fan Always
Chevy Fan Always's Avatar
Re: Bunch of Parts
Does the horn work and also what "note" is it?
Chevy Fan Always is offline   Reply With Quote
Old 05-25-2019, 07:19 PM   #34
cashforclunkers
Re: Bunch of Parts
Got your payment curt and anew,
Sent madkidd a message.
Chevy fan I'll try to figure that out for you.
Thanks everyone
Joel
Burb parts for sale
Old 05-28-2019, 01:19 PM   #35
cashforclunkers
Re: Bunch of Parts
All 7 of you who purchased parts they have shipped today UPS ground. Let me know if you would like the tracking and I can provide that.
Joel
Burb parts for sale
Old 05-28-2019, 01:19 PM   #36
cashforclunkers
Re: Bunch of Parts
I tried the horn it doesn't work so I tossed it and removed it from my post. Thanks for checking.
Joel
Burb parts for sale
Old 06-04-2019, 02:07 PM   #37
cashforclunkers
Re: Bunch of Parts
ttt. everything in pictures is still available. more going up soon. Thanks
Joel
Burb parts for sale
Old 06-04-2019, 03:24 PM   #38
BlueBoy72
Active Member
Re: Bunch of Parts
Received my parts today.Just what the Doctor ordered!!
Thanks,
Elvin.
BlueBoy72 is offline   Reply With Quote
Old 06-06-2019, 09:28 AM   #39
cashforclunkers
Re: Bunch of Parts
More stuff. Pulling parts from a 71 donor cab. Had some good stuff up and around the dash.
First thing is complete almost totally uncut dash wiring harness w/ fuse box,
outside firewall plug and pigtail, taillight plug and pigtail
Truck had amp/oil/temp guages, no AC
Only splice on the whole thing is at the brake light switch for a trailer controller at one point I'm sure. Otherwise in good usable shape, but not tested. Little bit of corrosion on fuses, but none found on any of the plugs.
$65 shipped
Joel
Burb parts for sale
Old 06-06-2019, 09:33 AM   #40
cashforclunkers
Re: Bunch of Parts
Parchment 3 on the tree steering column.
Everything's there including mounting brackets and rubbers. Center shaft is in good shape (I used a puller not a hammer) and bearing is good. Blinker switch is there but hazard switch is broken off and turn signal stalk is rusted. Truck was converted to 4 on the floor so might not have much wear on linkages.
sold
Non-AC inside heater box. Great shape. All doors and cables are moving and not stuck. No Rust. Firewall gasket is good.
$60 shipped
Joel
Burb parts for sale
Old 06-06-2019, 09:37 AM   #41
cashforclunkers
Re: Bunch of Parts
-Pair of parchment defrost vents. Not cracked or broken sold
-medium olive ash tray. rusty cb clip
-jack hold-down spring
$10 ea shipped
Joel
Burb parts for sale
Old 06-06-2019, 09:46 AM   #42
cashforclunkers
Re: Bunch of Parts
71 pedal pivot assembly with bolts, missing pedal itself
Pair of fresh air doors. Good rubbers, all there. Rusty levers
Medium olive glove box. Has some Patina. Base model SPID. Good hinge, guide, 3 screws and clips. No latch.
25 shipped each
Joel
Burb parts for sale
Old 06-06-2019, 09:54 AM   #43
cashforclunkers
Re: Bunch of Parts
Faded parchment Chevy horn button with all the guts. 25 shipped
Wiper transmission. Not stuck. Including weird little bolts. Surface rust. sold
Locking glove box latch. no key. Have matching ign switch too but it's stuck in the dash. sold
Steering column / pedal box brace. Good rubbers. 15 shipped
That's it for today folks.
Joel
Burb parts for sale
Old 06-06-2019, 10:58 PM   #44
Getter-Done
Getter-Done's Avatar
Re: Bunch of Parts
I will take the Column
(Parchment 3 on the tree steering column. )
(Everything's there including mounting brackets and rubbers. Center shaft is in good shape (I used a puller not a hammer) and bearing is good. Blinker switch is there but hazard switch is broken off and turn signal stalk is rusted. Truck was converted to 4 on the floor so might not have much wear on linkages.
$40 shipped)
In addition to this message/// I received Cab lights Fast shipping well packaged Thank You
84 Chevy K-20
Old 06-07-2019, 09:38 AM   #45
cashforclunkers
Re: Bunch of Parts
No problem. Appreciate the repeat business! I'll get it shipped Monday.
Joel
Burb parts for sale
Old 06-07-2019, 06:28 PM   #46
Getter-Done
Re: Bunch of Parts
Payment sent
84 Chevy K-20
Old 06-13-2019, 04:37 PM   #47
cashforclunkers
Re: Bunch of Parts
ttt
Joel
Burb parts for sale
Old 06-13-2019, 05:11 PM   #48
richard2717
Equal opportunity joke ofender
richard2717's Avatar
Re: Bunch of Parts
is that $10 shipped for both parchment vents? I will take them if no damage to the tabs
Members I have met.
Dually Jams, OlBlue60, ScottH, Tommyboy24, Dujobo, Warbucket, 2003 Silverado, Notsolo, my90k5, 6t727t2, Special-K ,Jack_71C10, tabarcus,72blazer_mud_bogger,pwdcougar,RSavage,EricSean,1Rippen6,invicta455,tennaragtop71,arks, Kendal,Bennett68C10, Perpendicular, Chainsawman, McGeesCustomMinis,ShortbedClayton,longblue72,6768chevylover,Tim71,Travisarmenta,Ol' Drippy,fleetmitch,georgieb51,Dave,bcnya2,Dadsburb
https://paypal.me/6772GMtruckparts
Most women like the strong, silent type… Fortunately for me, my wife prefers the out-of-shape, mouthy type.
richard2717 is offline   Reply With Quote
Old 06-14-2019, 06:39 AM   #49
jaros44sr
jaros44sr's Avatar
Re: Bunch of Parts
will you take 15 for the ws wiper trans linkage
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
Old 06-14-2019, 09:03 AM   #50
cashforclunkers
Re: Bunch of Parts
Richard yes correct no damage.
Sure will.
Joel
Burb parts for sale
