Old 07-31-2019, 11:24 AM   #26
weedoublewide
Re: LS bypass fuel pressure regulator question
Does it matter what size line is used for the return back to the tank?
weedoublewide is offline   Reply With Quote
Old 07-31-2019, 06:21 PM   #27
ls1nova71
ls1nova71's Avatar
Usually its 5/16 to match the return size on the rail, or the filter/regulator.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
Old 08-06-2019, 10:28 PM   #28
weedoublewide
Got it, and what pressure can we expect to see on the return line?
Thanks,
double
Old 08-07-2019, 02:18 AM   #29
ls1nova71
ls1nova71's Avatar
There's no real way to measure it, but it wont be much, its low pressure on the return.
Old 08-07-2019, 06:00 AM   #30
mongocanfly
Post Whore
mongocanfly's Avatar
Agreed with ls1nova...the return is free flow with no head pressure to the tank...
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 08-07-2019, 08:21 PM   #31
weedoublewide
PERFECT, I can try my experiment now.
Thanks guys!!!
Old 08-07-2019, 08:35 PM   #32
weedoublewide
Another quick question....if I have the corvette bypass pressure regulator....does it regulate the pressure down or do I need a regulator downstream of that reg/bypass as well??
Old 08-07-2019, 08:41 PM   #33
prodjay10
It regulates fuel pressure.
prodjay10 is offline   Reply With Quote
Old 08-07-2019, 09:29 PM   #34
ls1nova71
ls1nova71's Avatar
Thanks guys!!!
Experiment???
Old 08-07-2019, 10:46 PM   #35
mongocanfly
Post Whore
^^^pics or it didnt happen ^^
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 08-08-2019, 11:34 PM   #36
weedoublewide
I missed it on the spec sheet, reg's it down to 58...Thank you sir!!
Old 08-08-2019, 11:36 PM   #37
weedoublewide
Originally Posted by ls1nova71 View Post
Experiment???
I'll be doing my experiment this weekend and ill post some pics of the results for you photo hungry folks!
Old 08-10-2019, 10:13 PM   #38
weedoublewide
So I took what nsb29 setup for his fuel return system and adjusted it slightly. As I'm not the best at welding, but decent at soldering.
I was working on the fuel line stuff today and took my pops with me. He's moved from a mechanic job to a sales/specialist job, kudos to not working in the Texas heat now. But he's been mentioning how he doesn't get to use his hands much anymore. So I was like, COME WITH ME..I'll put you to work lol.
So here he is getting the unit out of the truck
Next, we wanted to take nsb29 idea and modified it.
Instead of having two sending units, I condensed it to one sending unit with a return line cut and solder'd it in.
So first was to unsolder one of the pipes from a sending unit and clean it up
Drilled a hole in the new sending unit, and placed it in.
Then finally used some soft solder and a torch and place'd her in her new home
Old 08-10-2019, 10:15 PM   #39
weedoublewide
Still need to clean it up a little with some scotch bright but pretty happy with it.
gotta cut it to length and put the pump and filter on...one beer job lol
QUESTION,
where can I get the fuel pump wires that connect to the pre-existing wires that came with the pump? its the walbro pump I believe
Old 08-12-2019, 07:01 AM   #40
clay68c10
clay68c10's Avatar
Nice work! I did something similar when i added TBI to a previous truck.
Do you mean a wiring bulkhead where it passes thru the sender top? Gotta be something out there for that. You can just use the sender/hanger for the ground, and only run the power side thru the top. Maybe use the level sensor pass thru out of another sender.
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO
http://67-72chevytrucks.com/vboard/s...d.php?t=788602
93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday...
05 Jeep Wrangler Unlimited. 3” lift & 6-speed
02 E320 the insurance total “free car”
13 Tahoe LTZ
clay68c10 is offline   Reply With Quote
Old 08-14-2019, 08:27 PM   #41
weedoublewide
Yea I picked a small little do hicky thing up at summit when I was out their this past weekend. I haven't got around to installing it yet, working outside all day long then going to work on the truck in the garage after that doesn't sound very appetizing lol.
OH, I do have a question....should I use PTFE type wire when running it in the gas tank? I read somewhere that the THHN type will, well it won't stand up.
Thank you,
double
