Old 06-25-2019, 06:55 PM   #26
kipps
Re: Those of you who converted to rear disk, can you feel much of a difference?
Originally Posted by SCOTI View Post
HydraBoost pedals are different. Did you swap pedals too? The brake pedal (leverage) ratio is different between the two. Obviously, the brakes will still function but not as intended.
Yes, I swapped the pedal.
The hydroboost pedal came from an automatic transmission truck. My truck is a manual. I set both pedals side-by-side, and was looking for some way to move the pivot pin on my manual tranny pedal. Then I realized that I could just cut down the foot pad on the automatic pedal, and use that. I used an angle grinder to shorten the foot pad, and the rubber cover for a manual pedal fit right on.
1987 C6P V20 truck, 2010 LMG 5.3, AFM delete, 2010 Camaro exhaust manifolds, 1997 nv4500, 1991 np241c, hydroboost, 2005 14bff axle & driveshaft, drop-n-lock gooseneck, 4.10 gears, stock suspension, rims, and tires. Still a work in progress. Any questions or suggestions are welcome!
kipps is offline   Reply With Quote
