Old 07-20-2019, 10:12 AM   #26
earl84
Re: Brake line coil off master cylinder necessary?
I went with no coils, but plenty of bends that should allow a little flex. Big project, but I’m glad it’s done. Got the front to rear proportioning set up. A lot safer now, and the brakes feel great. I put a residual valve in the rear brake line, which made it impossible for gravity bleeding, so that kind of sucked. Used my Motive brake bleeder, which makes a mess, but it got the job done.
earl84 is offline   Reply With Quote
Old 09-23-2019, 04:05 PM   #27
damnyankee36
damnyankee36's Avatar
Originally Posted by damnyankee36 View Post
...Mine is a 9" and I have to stand on pedal a little too much for my liking. That's what was offered from CPP so I didn't question the size.
Off topic again to clarify/correct my post...
I didn't realize that the reason I didn't have good power assist was not because of the size of the booster, it was the fact that the vacuum port I used on the 1" carb adapter was a blind hole. It was never drilled to expose it to manifold vacuum!
I didn't have poor power brakes; I didn't have any at all! I have since then attached the booster to the carb port.
damnyankee36 is offline   Reply With Quote
Old 09-23-2019, 04:18 PM   #28
The Rocknrod
Moderator
The Rocknrod's Avatar
Yep that'll do it.
