07-04-2019, 10:14 PM | #26 | |
Re: Help with my automotive ignorance pls
07-04-2019, 10:52 PM | #27 |
a bracket like that could be fabbed and placed on the inside of the firewall if need be.
07-09-2019, 09:29 PM | #28 |
All the MC booster kits I've found, like from brothers, come with support brackets. They wouldn't be sufficient to make it sturdy?
07-12-2019, 07:07 AM | #29 |
I had no idea how to do this either. I have an SBC 350 and a 700r4 in my truck. S10 chassis, but the rules were the same. I had to setup the engine and trans on the motor mounts and then check the angle of the intake manifold along with the angle of the transmission yoke. Lots of adjusting and eventually found the right place. I then welded a brace around the placement so it would stay. I still want to go back in and make it stronger later, but so far it has held up the past few hundred miles. i believe the angle is 3 degrees for the S10.
Current Build Thread 1930 Ford Model A Modern Twist: Ford Model A Rat Rod With a Modern Twist Build Thread Phase 1 "The Swap": 1949 3100 with S10 swap. Beginner build with ambition! Build Thread Phase 2 "The Drop": Beginner Build with Ambition gets Air Ride |
07-12-2019, 08:07 AM | #30 |
Thank you for the pics |
07-14-2019, 07:43 AM | #31 | |
53 Chevy 3100, SBC 355, 700R4, S10 frame, Ford 8.8 rear with 4.11 gears, front disc & rear drum brakes |
07-14-2019, 08:01 AM | #32 |
Yes, at the transmission. Axle will point up.
1950 Build |
07-15-2019, 11:21 AM | #33 | |
To get everything to line up its all about where the front fenders meet the front wheels. I placed the engine and transmission down on 2x4 and the motor mounts. I put the cab down. I then lined up the front fenders and the core support (radiator). As long as the radiator isn't touching the front of the engine, that's about the place to put it. Nothing was bolted, drilled, or welded yet at that point so I could move things around. Then you get to take all that sheet metal off knowing where the engine and transmission goes
