Old 08-13-2019, 12:22 PM   #26
Matt Man
Matt Man's Avatar
Re: 1981 K10 project
Originally Posted by drmatera View Post
Matt, not sure yet. Most likely around 4" as I want to do the shackle flip on the back (which is typically 4" of lift) and i hear tuff country springs for the front because they ride decent. I'll let you know when I pull that trigger.
The 4" lift is good on these trucks as the raised steering arm is at stock levels so it drives really good. One thing you should also install is Off Road Designs sway bar relocation kit it made a huge difference in ride on mine as well as their steering box bolt in brace. I have the rancho springs which are typically stiffer as well.
86 c30 crew cab dually 454/400 4/6 drop SOLD 1-8-11
1981 chevy K10 short Bed Scottsdale SOLD 10-26-2020
67 GMC Stepside Straight six/3 on the tree "The Peach"
2020 Silverado Double Cab LT Z71 5.3 8 speed Daily Driver
K10 build http://67-72chevytrucks.com/vboard/s...d.php?t=671934
The Peach build http://67-72chevytrucks.com/vboard/s...d.php?t=733903
Matt Man is offline   Reply With Quote
Old 08-13-2019, 02:32 PM   #27
drmatera
drmatera's Avatar
Thanks for the tips.. I do plan on the steering box brace and was even considering their cross steer set up.
1981 K10 (4.8 / 4L60E swap)
1982 C10 (5.3 / 4L80E swap)
1985 C20 Suburban (454 / 4L80E)
drmatera is offline   Reply With Quote
4x4, k10, one owner, scottsdale
