Old 12-25-2003, 05:49 PM   #26
smashingchuck
It'd be alot cooler if you did
smashingchuck's Avatar
Originally posted by Slammed67
[B]
I don't quite understand why you had to space out your power steering pump.[B]
OK, it breaks down like this... I wanted to mount the pump as far forward from the engine to avoid any clearance issues with headers, valve covers, steering, whatever. So I moved the steering pump forward so I could then use the groove closest to the pump to drive it. In doing that, the groove farthest from the pump is now free to run my Air Commander. This also allowed me to mount my huge bracket directly to the accessory holes on the head, and put the super goofey Gm Braket on top of it - only about an inch forward. get it? It was my only really clear solution short of incorporating the york bracket and the power steering pump brackets into one.
So you just have a belt going from your power steering pump up to the York?
yes.
I designed my bracket so the groves on the York would line up with the grooves on the power steering pump.
So did I.
My York has a dual groove pulley
Mine has a single groove pulley.
Does yours slip at all?
no.
78 Build Thread
4Runner Build
smashingchuck is offline   Reply With Quote
Old 12-25-2003, 10:49 PM   #27
Shev
Head Peon
Shev's Avatar
Now to throw a wrench into the formula...I need a bracket for a big block for my '72 burb. The one I had told you I wanted is going on my S-10. Any thoughts?
'72 Suburban, factory tilt, tach, front & rear AC, front & rear disc brakes, 383/700-R4
Shev is offline   Reply With Quote
Old 08-28-2012, 06:18 PM   #28
Sick5
C10 CLUB Y QUE!
Sick5's Avatar
Re: York...
Originally Posted by FuelCellGuy View Post
here's a pic of the bracket I made.
you got any more picture of the bracket?
Sick5 is offline   Reply With Quote
Old 08-29-2012, 03:51 PM   #29
ChopperCity256
ChopperCity256's Avatar
Re: York brackets
I would also like to see more pictures. i just bought a york 209. anybody still making brakets for this? i have a sbc motor..
ChopperCity256 is offline   Reply With Quote
