#26 |
Hoarding Rusty Objects
If it didnt whine when the amp wasnt working then I doubt its the head unit, but still check the ground. Check the cables and speaker wires, also triple check the ground on the amp.
1985 Chevrolet K20 Silverado 1994 GMC Yukon Follow me on Youtube! - http://www.youtube.com/user/FuelInjectionSucks |
#27 |
The amp was dead shorted to zero ohm input thru mute cables this test so I am told eliminates the amp ground and the amp as it would make the whine.
1968 c10 lowered 3" 4" 355/Th400 built by Hatfield racing in joplin MO |
#28 |
Stylin
also does it whine more when u rev the engine up? if it does its alt. feedback
Ive been traveling for some time, with my fishin pole and my bottle of shyne. Most Girls like finished products and just dont understand what a good addiction does for you http://www.paulwall.us/ |
#29 |
Yes I am almost certian it is alt whine anyone try those alt noise blockers that mount at the alt?
#30 |
Available for Adoption
You want to also make sure that you have a good engine to chassis ground, as well as cab to chassis ground. Yes, you have isolated it to the amp somehow. Like mentioned earlier, make sure the pwr wire isn't running along side the RCA's and double, tripple and quadruple check ALL grounds. It's just electricity not rocket science.... Use an ohm meter to check the resistance between the amp chassis and ground (depending on the amp), should be .5 or less (.1 is best) Then check engine to frame and then body to engine and frame. If nothing else, make a long jumper and go straight to the battery (negative post)...If problem still persists, it's the amp or a crosstalk situation with your wiring.......I'll bet money you find it to be a problem with the ground.....
Good Hunting....
1983 C10 SWB ![]() ![]() |
#31 |
Up date Installed A Ground Loop isolator from schoshe(sp) noise gone. sweet.
