09-27-2019, 09:12 PM | #26 |
Re: '71 GMC 2500 exhaust manifold (350) interchange.
The only time I have seen a manifold turn cherry red was when it was run on a Dino at WOT and maximum load. That kind of sustained heat will do that to cast iron.
09-28-2019, 12:00 AM | #27 |
On earlier vehicles where you manually control the spark advance having the spark severely retarded will do it too, but in this case I haven't had the timing slip and when you run that heavily retarded you'll eventually see the coolant temp rise, which also hasn't ever been an issue.
09-29-2019, 08:59 PM | #28 |
I swapped out the manifolds last night and had it running before bed. Took it out for a drive after tidying up some things this morning and it's still the same great running truck it always has been. While the manifolds were off I pulled the plugs and did a quick compression check. Everything is about 150lbs+. Timing is exactly where it's supposed to be and nothing is amiss. Thanks to everyone for helping me quickly resolve the part application issue so I could get this out of the way before the week started.
09-29-2019, 09:19 PM | #29 |
Moderator
Many thanks for the update!
The folk here love to help everyone out... Enjoy your truck !
Family and country before all others... 2006 Chevy Silverado (Daily Driver) 2012 Chevy Equinox |
09-29-2019, 09:34 PM | #30 |
I know how people like to see these old beasts still in service. This was back in the spring dragging home a new piece of iron.
09-30-2019, 09:35 AM | #31 |
Old member
Glad you got it going again. Those manifolds will blow out like that if you hit them with water after a long hard run. Are you open the hood up after a long run in the rain the rain runs off the hood down into the motor. Over time they get weak and will blow out.
