#26 |
Re: Led frount turn signals/park lights for GMC?
I better hurry up and send these. I can't wait to see them done. Clear lenses? My originals are getting pretty close to that!
#27 |
Got all the other leds Installed a couple of days ago. Figured I'd post a vid up here. Oilve is now put away for the winter. Other wise I would just show some pictures. https://youtu.be/nmTLkR-0obk
![]() 94 chevy k1500 350 tbi 373 rear gears 4l60e one wheel peel. Gutless 07 gmc sierra classic rcsb 4.3 lt 5 speed w/t 04 chevy Silverado 1500 ext cab 5.3 4l60e. 81 chevy Scottsdale k10 muncie sm465 Np208 10 bolt 8.2 ( Old Green) |
#28 |
![]() Join Date: Feb 2004
Here they are boys! I ain't gonna lie it was a bit of a challenge...they have to have mounting tabs to install and be secure. But they look awesome! Check out the video
Watch "67-72 GMC front LEDs custom made to order!" on YouTube https://youtu.be/CY7xWsYr-Sk
The Ghost 67 short wide full custom. 550 hp LSX, 4l80E, narrowed 9". Body dropped w/air ride! ........................ ___ .........________//__{\_____ ,,,,,,,/__(⊙)___//___/__(O)_/ @disciple2.rc 💪instagram💪 LED TAILS |
#29 |
Couple more!
#30 |
Old member
Just saw the video good job sir!
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
#31 |
Thanks Andy!
#32 |
Way to go brudda! You da man. In all seriousness, Rob, you've done a fantastic job.
#33 |
Thanks sir!
#34 |
Old member
You know I'm going to want some 68 Tail lights and front parking lights for the step side right!
#35 |
Lol, hit me up when you get ready, im fixen to have to reorder supplies...i been busy the last month 😁
#36 |
Those look fantastic Rob! I almost wish I had a GMC to match the tail & reverse light I bought from you lol.
72 C10 lwb fleetside -stock 350/350 combo |
#37 |
👊👊👊👊 thanks bro!
#38 |
They look so good. I'm pumped now. Asome jon as usual rob.
#39 |
Active Member
![]() Join Date: Feb 2017
Front lights are looking good!!!!
I sent you a PM about front and rear lights for my GMC. Thanks. |
#40 |
Active Member
Front and rear assemblies ordered !!!
#41 |
Got the first set in the mail today. Can't wait till spring when I can put them in. I did some bench testing and they are much briter then led replacement bulbs. The plugs a real tight fit. But does fit.
#42 |
Great now I need a new plug and from what I'm told you can't get them new.
#43 |
I figured it would be tight because of the way the socket fits in. Glad you like them!
#44 |
Tight is good. The little harnesses need to be found used. Check the parts board. The aftermarket treats GMCs like their red headed step child. Thanks to Rob they're being well treated in the L.E.D. lighting area. Now who can make these light harnesses? I never checked, is the plug the same as Chevys, just different length harness?
#45 |
Old member
You should be able to use a genric 2 wire hook up in it if you take care taking it a part.
Yes it says Ford, but it also says: Double Contact Socket Assembly. Fits 11/16" (17.5mm) Hole. Replaces GM #88860428. Replaces AC/Delco #LS126. Uses bulb #198, 1016, 1034, 1154, 1157. https://www.wiringdepot.com/store/p/...BoCJQ4QAvD_BwE ![]()
#46 | |
#47 |
These bad boys are ready to go!
#48 |
Old member
Somebody gonna be a happy GMC owner with those!
#49 |
![]() Join Date: Nov 2012
Those are UNBELIEVABLE!!!
I badly want a set, but we have a law in SC against a "signal light" emanating a "glaring or dazzling light". I must check to see if these are considered as such before purchasing any. Hard to believe something that makes a vehicle easier to see could have a law against it.
FRANKENTRUCK 1981 Chevrolet C10 Shortbed Stepside GRANDTRUCK 1968 Chevrolet C10 Stepside Longbed http://67-72chevytrucks.com/vboard/s...d.php?t=584617 PROJECT JIGSAW 1967 GMC C3500 GREAT WHITE 1986 Blazer M1009 |
#50 | |
