Old 10-28-2019, 07:29 PM   #26
toolboxchev
Re: Does this look right?
Originally Posted by AussieinNC View Post
Sadly so many fall for the old "its a Corvette engine".....
heehahhaahheheheheheeee!
toolboxchev is offline   Reply With Quote
Old 10-28-2019, 10:14 PM   #27
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: Does this look right?
Ok drove the ramp truck today and it did fine. It did back fire once but after that it did fine. It was right after I cranked it up for the first time. It cut off and when I went to refire it it back fired. I didn't have anymore problems after that it drove good and the brakes even seemed better. I guess the vacuum leak was hurting the booster effect on them.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 10-29-2019, 07:22 AM   #28
Ironangel
Ironangel's Avatar
Location: Falls City, Nebraska "100 Miles From Nowhere"
The missing link COPO Corvette motor! Backfiring through the exhaust when you let off the pedal is an exhaust leak. Whats the block casting number?
Michael of the clan Hill,
"Two Seventy Two's"
71 1-ton Dually 350 4-Speed
71 C/50 Grain Truck, 350 Split-Axle 4-Speed
02 3/4 ton Express
14 Indian Chief Vintage
1952 Ford 8N, "Only Ford Allowed On The Property"
"Be American, Buy American"
Ironangel is offline   Reply With Quote
Old 10-29-2019, 09:23 AM   #29
Andy4639
Old member
Andy4639's Avatar
No backfiring through exhaust. It popped through the carb but after that it was fine the rest of the day. It could have been me trying to cold start it also. Pumping the gas pedal while cranking it! I drove it all afternoon and cut it off several times and never did it again.
Fixing to go drive it again to the shop to work on pulling the 68 cab off I hope.
Old 10-30-2019, 10:01 AM   #30
Steeveedee
Who Changed This?
Steeveedee's Avatar
I have found two bolt carb mountings on 70's on engines, mainly 305's....
Has the OP determined the engine is a 350 ?
As the OP mentions the engine is not original...it may just have the small port 2 barrel manifold bolted on...
Oh, yeah. I remember those now. I think they did it starting in '71? I worked for a dealer in those days. You'd think I'd remember that. :shrug:
~Steven
Simi Valley, CA
Steeveedee is offline   Reply With Quote
Old 10-30-2019, 06:36 PM   #31
BigBird05
As others have said 307's of that era did come with just 2 carb studs and nuts.
BigBird05 is offline   Reply With Quote
Old 10-30-2019, 08:22 PM   #32
Steeveedee
Who Changed This?
Steeveedee's Avatar
I guess with a cast iron base and a vacuum underneath, the carbs just got sucked down onto the gasket! One thing that Chevrolet got bit on the booty with though was putting 2-row radiators in the '71 big cars with the 400 small block. We had a line of them in the service lot with severely overheated engines. All got a retrofit to a higher row count radiator. Ever seen a blue torque converter!? That's some hot stuff, right there.
~Steven
Simi Valley, CA
