#26 | |
Re: Find My Shift Boot..
If you are not happy with that replacment one you found, I would look in to Dodge, since they are pretty much where the first ones to use the New Process 435 , The NP 435 was used in dodge trucks since the early 60s all the way to 93 , So you may have better luck in your search for a OEM one with proper fitment. |
#27 |
![]() Join Date: Feb 2019
Got the new Shift boot installed today, Looks pretty good.
Now I can say My C20 is "Kenworth Equipped"
1968 C20 Fleetside 396 4sp PS PB AC CST . https://www.youtube.com/watch?v=RWK8GgWD4uA |
#28 | |
NP435 Four-Speed (Truck) Type First Gear Second Gear Third Gear Fourth Gear All 4.78 2.39 1.37 1.00 https://www.onallcylinders.com/2017/...hevy-vehicles/
#29 |
I was linked to this thread since I just came across the same issue. Ironically, my 68 C20 is a 396 4sp just like Astro-Balls, and apparently with the same NP435 transmission as well
![]() From the SPID: "HD 4 SPD CR TRANS" ![]()
'68 C20 Utility 396 4sp (BuildThread: http://67-72chevytrucks.com/vboard/s...d.php?t=806904 ) '68 C10 50th |
