Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > Welcome and Discussion > General Discussion
Old 12-18-2019, 01:14 PM   #26
GOPAPA
GOPAPA's Avatar
Re: Tools you can't live without
I do have a small tool that has been my backup for many many years when working for construction company's or working for myself.. I still use it ..
My kids bought this for me some 25 years or more ago $89.00 now on Ebay about $15-$20 w shipping
When you learn a thing a day you store up smart.
GOPAPA is offline   Reply With Quote
Old 12-18-2019, 01:26 PM   #27
68C15
blood type; Retumbo
68C15's Avatar
Originally Posted by 1976gmc20 View Post
So about 11/16". Now I have to drive 50 miles round trip to town in another vehicle and see if the only parts store in town has one. I better call them first so they can order one. It's only been about 1000 miles since it was serviced but quite a bit of time as I don't drive it much, and you never know with old pickups.
go to hardware store and buy a 12mm bolt and nut. They are 17mm hex. Cram the nut on bolt real tight then use a wrench to get plug out.
Man rule #77...if you own a 67 stepside with a caddy 472 you will never be in danger of loosing you man card
68C15 is offline   Reply With Quote
Old 12-18-2019, 05:54 PM   #28
1976gmc20
Or …
It turns out you can take a long 11/16" nut and file a bit down on all six faces of one end to get it down to 17mm
Thanks for the idea!
Oil level was fine, BTW. But the SOB at the last shop must have used a 3/4" breaker bar to put it back in
Current/past Chevy/GMC trucks:
1958 Chevy C-60; 1965 GMC C-50; 1965 Chevy C-10; 1971 Chevy K-10; 1973 Chevy K-20; 1976 GMC C-20; 1977 Chevy C-10 Suburban; 1980 Chevy K-10; 1989 Chevy K1500; 1991 GMC V1500 Suburban; 2016 Chevy K2500 HD
Other vehicles: 1988 Jeep XJ; 2011 Toyota 4Runner
1976gmc20 is offline   Reply With Quote
Old 12-18-2019, 06:47 PM   #29
mick53
Attachment 1966877
I had one of those. If I remember right they were very expensive when they came out.
mick53 is offline   Reply With Quote
Old 12-18-2019, 07:28 PM   #30
Jrainman
Jrainman's Avatar
I would be lost without my 5-20 lift , cant tell you how many times I have used this to get me done , cabs ,beds, frames , are just a fraction of what I have used it for , it will reach 22 ft high .
Jrainman is offline   Reply With Quote
Old 12-18-2019, 08:09 PM   #31
GOPAPA
GOPAPA's Avatar
A lift like some of you have shown above would of been a great help when I lifted my 402 engine up to put in big block motor mounts,, instead I used a hydrolic jack and ropped the motor and in the process I was told I warped my frame by losing the motor off the jack.. anyway sold the truck when I moved and will never know for sure if I did it or it was done before I got the truck ..
As for the calculator ,,one might not believe this ,,but I do not remember ever changing the lithium battery out for a new one "ever' it is solar and it shuts off after each use with in minutes ,,so after 25 years one would think I had to change it more than once and like I said ,, I do not remember changing it even once .. let you all decide about this statement ,,except I am not one to BS about it,,
Old 12-18-2019, 08:51 PM   #32
Steeveedee
Ram-A-Lam-A-Ding-Dong
Steeveedee's Avatar
Or …
When I worked as a mechanic it never ceased to amaze me how tightly guys seem to have to make the oil pan drain plug, or any drain plug, for that matter. I had a regular customer come in for an oil change, and the other guy did the oil change that time. He was surprised how easily the plug came loose, and commented to me about it, because he knew that I was the last one to change oil in that car. I just said, "Was it leaking? That's all the tighter the plug has to be." I've NEVER had one fall out, and also never stripped one.
~Steven
Simi Valley, CA
Steeveedee is offline   Reply With Quote
Old 12-19-2019, 02:09 PM   #33
1976gmc20
Yeah, and this was just the side fill/check plug on an aluminum transmission! Not even the drain plug on the bottom of the gearbox.
I used a 1/2" ratchet and socket on the "tool" that I made, and still I had to get the handle horizontal and lay on my back underneath and pull down with both hands for all I was worth (not so much anymore, I guess ).
Old 12-19-2019, 03:25 PM   #34
rpmerf
rpmerf's Avatar
Did you try to loosen the plug while the trans was hot / warm? Can make a decent difference.
1970 C20 Custom Camper - 350, TH350
1997 GMC Suburban
1994 Acura Integra GSR
1987 Dodge Daytona Shelby Z
rpmerf is offline   Reply With Quote
Old 12-19-2019, 06:17 PM   #35
1976gmc20
No, it was about thirty degrees and a miserable wind blowing
Though I suppose that I should have driven a pickup that I suspected might be low on oil in the transmission (it wasn't) until it got good and hot. Plus there would be the added advantage of burning myself on the exhaust pipes. OTOH if the transmission did get fried then I would have saved myself the effort of having to check it
Old 12-22-2019, 05:14 AM   #36
Greasey Harley
Greasey Harley's Avatar
Power Probe.
Greasey Harley is offline   Reply With Quote
Old 12-22-2019, 05:40 AM   #37
FleetsidePaul
R.I.P. E.S.L.L.
FleetsidePaul's Avatar
My phone. Call someone else to do it. I'm retired.
1971 Custom C/20
1970 CST 20
1970 C/30 Flatbed
1983 C/30 Dually
2015 Corvette Z51 2021 Corvette Z51 1991 Cadillac Hearse 1982 Cadillac Eldorado Biarritz 2000 Porsche Boxster S 2020 Jeep Gladiator 1973 VW Thing 1973 Plymouth Satellite wagon 1963 Baja Bug 1959 Bug Dune Buggy 1970 Baja Bug 1987 Jaguar XJ 350.
R.I.P. El Jay
R.I.P Jessie.
R.I.P Grumpy.
Every day is a gift from God.
FleetsidePaul is offline   Reply With Quote
Old 12-22-2019, 07:58 AM   #38
4u2nv
When I get in a jam this is my must have tool
4u2nv is offline   Reply With Quote
Old 12-31-2019, 03:06 PM   #39
dajn
M18 impact driver. I use that tool all the time. From light mechanic stuff to carpentry work. It's one of those tools that has made things so much easier and faster. I see people all the time use drills.. a drill is only good for one thing. An impact driver can do so much more. So you need both.
dajn is offline   Reply With Quote
Old 01-01-2020, 01:21 AM   #40
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
I noticed a lot of people said their Bobcats. I ran across this and thought it would be interesting for some.
https://ironsolutions.com/news/the-f...i-dVeLZgHb_-TU
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 01-02-2020, 11:22 PM   #41
shifty
Questionable
shifty's Avatar
Originally Posted by richard2717 View Post
forgot the more important one nowadays (eyeglasses)
This one hit home for me.
Was diagnosed legally blind while not wearing corrective lenses ... in the 4th grade. All distance stuff, was in excess of -7.0 in both eyes.
Started wearing contacts in 6th grade. Wore those til I was in my late 20s and then-undiagnosed autoimmune disease made the eye docs tell me my eyes were too dry to wear them. Around 30 the FDA finally approved contact lens implants as a fully-reversible-alternative to lasers, so I was 1st in line to get that done.
Went for more than a decade after that seeing like an eagle, although the change in my focal point made close-up things like soldering less easy than it used to be, but still manageable. I used to laugh at the parents and in-laws breaking out flashlights and glasses to read menus in moderately-lit restaurants. People would always say, "Don't you worry - wait til you're 40, you won't be laughing anymore". Yeah, right.
Hit 40. Near vision is still excellent.
Then 41. Near vision is still excellent.
Then 42. Near vision is still excellent.
Then 42, 5 months, 2 days, I wake up as usual, pick up the phone to see how bad my day at work will be, same as every day, based on the amount of crap filling my inbox. But, damn, must be more eye-boogers than usual this morning, let me hold my phone a couple inches farther away...
Then 42, 5 months, 7 days, I wake up as usual, pick up the phone, and now I'm holding the phone a foot farther away.
By 42, 5 months, 16 days, suddenly my right arm isn't quite long enough for my right eye, so I'm reading with my left arm out away with my elbow at a 15-20° angle.
HUH.
I think I was more shocked at how quick it happened. I expected it would all unfold over a few years. But naw, was literally about 2wks start to finish on the worst of it, bad enough I booked a next-day appt with the eye doc because they warned me any massive changes in vision could be a retinal detachment related to my ICL surgery. Before a month had passed, suddenly flashlights were really helpful on smaller text.
And now I'm back needing glasses again. At least I got a good 15+ years out of the surgery. Most of my friends who got LASIK were in readers 5-10 years early, almost all within 5-6 years of their first burn. On the positive, I can still get mine reversed.
But I have no shortage of readers now. Just need a light +0.75 or so for close-up tasks, and keep a pair of +2.0 around for when I'm soldering or fidgeting with the super-fine stuff.
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link)
I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM.
shifty is offline   Reply With Quote
Old 01-03-2020, 02:33 PM   #42
weq92f
weq92f's Avatar
<snip>...
I think I was more shocked at how quick it happened. ...
You are not alone!
This happened to me about the same time. So yes... readers are the first tool I require before using any other tools.
I'm now in the market for some 10x goggles for fiddling with really small stuff.
-klb
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi
07 335 sport turbo 6sp
94 Trans Am GT LT1 6sp posi -- sold after 22yrs
99 540 sport V8 6sp -- sold
73 240z L24 4sp -- given to friend
68 C10 step 350/350 3.73 open -- sold
weq92f is offline   Reply With Quote
